throttle pull or push-pull???
  • le_bucheron
    • Sep 2012
    • 45
    • Montreal, Quebec, Canada
    I bought some yzfr6 controls so I need a new throttle cable holder. I'm not sure if I should use some push-pull style or only pull???
    Thanks Guys!!!
    83 XJ1100
    06 FZ1 naked abarth
    Our carbs are spring-loaded, and handle the "pull" part all by themselves. Some bikes use 2 separate cables - one for pull, and one for push. Ours are just "pull" style.
    • le_bucheron
      • Sep 2012
      • 45
      Do you think i can buy a push-pull style and use only one cable? Here a big deal on ebay for a motion pro push-pull
      http://www.ebay.com/itm/271149520060?redirect=mobile
      83 XJ1100
      06 FZ1 naked abarth
        I guess you could. Does your bike not have the throttle tube? Or does it not fit the controls?
          Originally posted by le_bucheron
          Do you think i can buy a push-pull style and use only one cable? Here a big deal on ebay for a motion pro push-pull - - -
          Hi Robin,
          what do they (and what do you) mean by "push-pull"?
          Control cables DON'T push, they only pull. A 2-cable twistgrip has one cable to pull the carbs open and another to pull them closed.
          (Hey! Desmodromic carbs! But I digress.)
          If that Motion-Pro twistgrip works 2 cables, most likely it will work with only 1 to operate spring-return carbs.
          Be careful which cable though, the other one will reverse the throttle operation.
          However, that particular twistgrip says it's for off-road use.
          Which may mean that it has a bigger than normal cable drum diameter to give a rapid throttle opening, usually a ~1/4 turn instead of ~1/2.
          You sure you want that on an XJ11?
          • le_bucheron
            • Sep 2012
            • 45
            Hi Robin,
            Yeah push-pull mean for me a 2-cables... I will try the motion-pro but if you look on is web site a single cable or double cable it's really not the same shape...
            83 XJ1100
            06 FZ1 naked abarth
            • le_bucheron
              • Sep 2012
              • 45
              Here some photo:
              83 XJ1100
              06 FZ1 naked abarth
