Does anyone know what size O-ring is on the bolt for the cct? Mine is leaking after replacing it with one I thought was the correct size.
CCT bolt o-ring size?
USMC 2005 - Present
79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
78 XS1100E - Rebuilt And SoldI SHOULD OF KEPT IT!!!
Tags: None
For the Stock CCT the o-ring part number is: 93210-06632-00
You can find it just about anywhere for about $1.5 to $2
Here's a pic:
Approx Dimensions: Thickness 1.9mm / Outside Diameter 9.85mm / Inside Diameter 5.8mm
Hope this helps.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather ride
Originally posted by GLoweVA View PostFor the Stock CCT the o-ring part number is: 93210-06632-00
Here's a pic:
Hope this helps.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
+1 on ditching the OEM tensioner and getting a auto tensioner!Nathan
For now I'm thinking about doing the 30 minute cam chain tensioner mod and see how that goes. Here is the link http://www.xs11.com/forum/showthread.php?t=35497USMC 2005 - Present
I just re-adjusted the cam chain tension this weekend and the tensioner has started to leak. I also noticed that the PO had installed the tensioner upside down (the bolt comes out on the left side of the bike instead of the right).
Do you suppose the direction of installation makes much difference?
The PO had globed RTV all over the lock nut and bolt, is it just an O-ring that goes there to seal the CCT?
Thanks in advance.Guy
1980 XS1100G - Frankenstein - resurrected from the impound lot
1991 Suzuki GS500E (not running yet)
2003 Burgman AN400 - Blue Belle
2005 Burgman AN400 - Silver Belle
