So I know there have been some threads about this, but I've already gone through and tried the suggestions, to no avail... I've thought about just bringing the carb body to a local bike mechanic who'd be familiar with it and have him get it out for me, but my ego has me wanting to give it one last try... Tried to drill a small pilot hole in it and use a screw extractor bit, but all that happened was the extractor bit removed more of the pilot screw which is obviously made of warm butter... Any help you guys can give would be amazing, pictures always help, and recommendations for what kind of dremel bit I need, etc. Feeling like quite the silly man at the moment...
pilot screw is destroyed...
Tags: None
Some have successfully removed stuck pilots but I'm not one of them.
What # carb is it? I'll see if I have one and you can just you can replace the body.Greg
The list changes. -
Certainly not trying to steal the thread here or step on any toes but .....noticed you mentioned you may have some individual carbs? I would be interested if you had a #3 with good float posts and such. This would be for the 78-79 style. #3 has the idle speed adj. on it. Thanks, BobComment
I had a similar situation, only I broke the extractor off inside the mix screw. I wound up taking the carbs to a machinist. He milled the screw out to the minor diameter and I was able to use a small Stainless nail to pop out the remaining material in one chunk.Life is what happens while your planning everything else!
78 XS750Comment
A #1 carb body will work there also if you swap out the butterfly shaft.Greg
The list changes.Comment
Hmmmmmmm
I believe it's the #4 carb, or #1... My pseudo dyslexia doesn't help much in this situation... It's the one to the far right of the bank (if you're looking down at the carbs while seated on the bike...). And I belieeeve the carbs are from an '81 midnight special... I actually have a spare body but I haven't been able to get the screws loose from the carb body's mounting points on the bracket... Already had to grind a large slot in the screws to get a big flathead screwdriver in but it has me feeling like quite the wimp... Any suggestions on this?81 XS11Comment
Lots of penetrating oil. Not WD-40, but PB Blaster or Liquid Wrench. Spray and let it sit, spray some more, let it sit some more. I have learned that this is the only way to work on these carbs.Life is what happens while your planning everything else!
78 XS750Comment
If trying to drill out something stuck like this, I always use a left-handed drill bit. Worst case, I drill a hole; best case, the bit breaks the it loose.
That said, I'm always nervous about taking a drill to something like a carb body..
Maybe a combination of penetrating oil and gentle heat?82J · 81SH · 79SF Fire Damage · 78E · 79F Parts Bike · 04 Buell Blast
Website/Blog
You will have a tough time drilling out that screw without clamping the body in a vise and indicating that hole. That is how I have done a few. But I do have access to a Mill. DGXSR is right. A Machinist will get it out right and quick.80 SG XS1100
14 Victory Cross CountryComment
Do you have a hand/hammer driven impact driver? They're great for getting out screws and such on these motorcycles.
If not, I got my second one at O'rielys for under $15.
I believe it's the #4 carb, or #1... My pseudo dyslexia doesn't help much in this situation... It's the one to the far right of the bank (if you're looking down at the carbs while seated on the bike...). And I belieeeve the carbs are from an '81 midnight special... I actually have a spare body but I haven't been able to get the screws loose from the carb body's mounting points on the bracket... Already had to grind a large slot in the screws to get a big flathead screwdriver in but it has me feeling like quite the wimp... Any suggestions on this?Guy
1980 XS1100G - Frankenstein - resurrected from the impound lot
1991 Suzuki GS500E (not running yet)
2003 Burgman AN400 - Blue Belle
2005 Burgman AN400 - Silver BelleComment
I've gotten those screws loose with a good pair if Channel Locks by grabbing the head and busting it loose or with a center punch and a small hammer on the edge of the head.
I hate those phillips screws, good idea to head down to the hardware store and get some allen bolts and replace them when you go back together with it.Greg
I'm not sure but I thing I had the same problem. I hope my picture will help you.
83 XJ1100
06 FZ1 naked abarthComment
Ouch!........that housing will still work fine though. Not so much for the idle mix screw. If it hadn't been ground so deep, could of re-slotted it with a dremal and the small cut-off wheel......makes a perfect srewdriver slot. Square it off and re-slot it. Even if slot ends up into a couple threads down, it'll work fine.....BTDT.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
1980 XS1100 Special
1990 V Max
1982 KZ750 LTD Twin
1974 CB750-Four
Past/pres Car's
1961 Catalina 389/1970 Torino GT 351/1967GTO 12to1 comp./ Roller cam/ T-10/ 456 gear/Tri-power/1967 GTO 400, 1969 Camaro, 1968 Z28, 2001 BMW M Roadster 0 to 60 in 4.5 sec. Jaguar XK8Comment
