gas?....what gas?
  • gas?....what gas?
    OK......carbs removed and back on, fuel lines ran under carb connecting tubes with filters. Filters are installed with arrow going towards carbs. Petcock rebuilt and flowing well. Left carbs getting fuel...rt. side none. No fuel in the line going to the filter on rt. carbs. Any info on this one?
    At this time:
    1985 Goldwing Innr.
    1976 cb 750 cafe racer
    2007 vtx 1300
    81 sx 1100 s h
    81 sx 400 special
    gas....what gas...
    Exactly, how full is your tank?
      Do you still have the octy and if so are you certain the lines are run correctly?
      2-79 XS1100 SF
      2-78 XS1100 E Best bike Ever
        Petcock
        Any fuel coming out of the right petcock?
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
          gas?
          1. No Octy.....2. Plenty of gas on rt petcock ( carbs 1&2 are running fine ). I have the rt petcock feeding 1&2 carb.they are working fine. 3. Tank 1/3rd full. I removed the turn handle on the lft. petcock while it is on the tank and its flowing good.....no restrictions. I have fire on 3 & 4 spark plugs.......dry when i remove them.
          At this time:
          1985 Goldwing Innr.
          2007 vtx 1300
          81 sx 1100 s h
          81 sx 400 special
            IF you get good flow at the petcock, the tank has plenty of gas, and you get no gas at the filter, it may be a kinked line, or it could be air locked.
            I know there are several folks that have used the cross fueling method (right petcock feeds left carbs and vice-versa) very successfully. I have never had success with that, I always get an air lock in the line. This is why I feed straight from left petcock to left carbs with an inline fuel filter. I loop the fuel line down to where it almost hits the engine when the tank is down, then comes up to the T at the carbs. This gives me plenty of line to lift the tank.
              What Doug said
              I never had much luck with in-line filters as a whole, but if you can get rid of the airlock it should work ok. Something else to check though with the specials is when you push the tank down into position, that final half inch, it can kink the line right at the petcock.
              mack
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              613-398-6186
                gas?
                Thanks guys.....all good stuff. I looked at running the fuel lines straight to the carbs......what kind of filters did you use?.....must be small ones?
                At this time:
                1985 Goldwing Innr.
                2007 vtx 1300
                81 sx 1100 s h
                81 sx 400 special
                  HERE is the fuel filters I use. I can get them from a local MC shop that deals in dirt bike and ATVs primarily. They fit between the air intakes of the carbs.
                    gas?
                    Thanks DG....I guess the filters i have now may be to big.
                    At this time:
                    1985 Goldwing Innr.
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
                      gas?
                      Well..well..well.......swapped out fuel filters.....ok.......still not running on 3&4 cyl., checked out 3&4 spark plugs....bad. Don't know how they went that way.......new when put in and not ridden much at all. Anyway.......up and firing on all cyls!!!!! Thanks guys
                      At this time:
                      1985 Goldwing Innr.
                      2007 vtx 1300
                      81 sx 1100 s h
                      81 sx 400 special
