leaking gas tank
  • XS1100 Newbie
    • Jun 2009
    • 1106
    • Battle Ground, Washington
    leaking gas tank
    Has anyone had a problem with the rear tank mount leaking? Last year i had the same leak. I used POR-15 on it, and took a lot of time to make sure everything was done right according to the directions. Even let it set two more days than i was supposed to, just to make sure it was cured. It did seal it, but now it is back, and worse. They said i now need to boil the tank to get rid of their product and redo it. I will have to weld completely around the rear mount, filling all the holes in the mount i guess. Anyone have a good solution? I reall don't want to have to paint my tank yet.
    1980 XS1100LG Midnight
    1991 Honda CBR1000F Hurricane
    A cold beer and another one!
    • 5069
    Nope. That is an odd place to have a leak.
    • XS1100_OEM4ME
      • Mar 2009
      • 1619
      • Fort Myers, Florida
      Red coat
      You can have it dipper and redcoated inside at a radiator and fuel tank shop, it will kill the paint job and that will need red-one.
      1980 XS1100 Special
      1990 V Max
      1982 KZ750 LTD Twin
      1974 CB750-Four
      Past/pres Car's
        • 8861
        I'm pretty sure Cobia had the same problem with his G, he used some kind of tank liner IIRC. His was leaking in an area by the tank mount that was inaccessible to braze/solder.
        • Rasputin
          • 3192
          • Lacombe, Alberta, Canada
          About a 150 buck fix in my part of the world but the acid dip and re-coat with the red liner worked well on two of my tanks.
          2-79 XS1100 SF
          2-78 XS1100 E Best bike Ever
          • XS1100 Newbie
            • Jun 2009
            • 1106
            I am a little afraid to trust the liner alone. That is what we did last summer. Need to close the leak with weld first, then seal. The tanking is just to get the old sealer out.
              • 8049
              I just finished putting a Caswell liner in my tank. It's now curing. I hope it works.
              Here's the chronicle of removing the old liner and rust, WITHOUT damaging the paint.
              XS650 Garage Tank Liner Failed.
              • XS1100_OEM4ME
                • Mar 2009
                • 1619
                Red Coat-liner VS Red Kote
                The process I was talking about at the radiator / tank shop is a permant fix. I used it on a BADLY rusted KZ tank. It involves a chem. strip that will kill the paint and then the red coat -liner (not "Red Kote") is a solid at roon temp, so it is heated / melted "very hot" and poored into the tank. When it cools, it becomes a THICK solid again forever (unless you bike catches on fire and burns at 1000 deg)
                It cost about 50 bucks back when I had it done, and any paint remainimg must be removed and tank recon / repaint is needed. But from me at the time, and after failed attemps to seal that tank, it was worth it, it never even thought about leaking again Clearly, not for minor easy fix, or great paint job tanks. My tank was black, so some 2k fuel res. rattel cans, wet sand and buff, gold 3M pinstripe and it looked better then new
                1980 XS1100 Special
                1990 V Max
                1982 KZ750 LTD Twin
                1974 CB750-Four
                Past/pres Car's
                  • 2074
                  Did you look on E Bay about a tank? I see them come up from time to time or contact Andreas Weiss-a member on this board.
                    Do look carefully on the Standard tanks, sometimes the leak is fuel draining out the drain tube for water that gets caught in the filler cap indent. DBeardslee has that happen to him. The tube rotted out inside the tank.
                    • XS1100 Newbie
                      • Jun 2009
                      • 1106
                      Got the tank all sealed up. Just about ready to roll.
                        • 8049
                        What did you seal it with?
                        • XS1100 Newbie
                          • Jun 2009
                          • 1106
                          Had it welded all around the rear mount.
