Broken Idle Mixture Screw Removal Tip
    • 9980
    I looked in the tech tips and I didn't see anything like this in the broken idle mixture screw removal posts. It works great.
    I had 2 broken mixture screws in the carbs from the E I just aquired. After spending a week and using every method, tool, and dirty word I had trying to get them out as I had in other carbs I finally broke down and ordered one of these.
    A pin vise drill. The best $30 I've spent in a while.
    It took me all of 30 minutes to get those stubborn broken ends ot of there!
    I just chose a bit that fit through the oraface and began to gently drill away at it. The thing is hand operated so it doesn't just rip stuff up.
    The aluminum is harder than the brass so it actually acts as a guide for the bit and keeps it digging at the brass and doesn't damage the carb body. When the bit came through inside the venturi the remainder of the tip just fell out.
    Just thought you might want to add this to the tech tips.
    This is where I ordered mine from but I'm sure there are other places to source them.
    We offer precision tools and supplies for all your hobby projects. Shop high-quality tools for model making, woodworking, painting, crafting and more!
    Great tip! We'll see if we get any comments before moving this to the tech tips!
      • 8878
      That is a good method, +1
      There are a bunch of cheap knockoffs on Ebay of these, need to buy the drill bits separately though.
        • 9980
        This one is pretty high quality. Anything on fleabay is a gamble.
        • tarzan
          • 1700
          • Chandler,Az.
          That looks like a good tool Greg. I have been looking for a decent quality one for work. Thanks for the link.
          80 SG XS1100
          14 Victory Cross Country
          • andylawcc
            • Dec 2012
            • 49
            • Los Angeles, CA.
            thank you very much! ! didn't know such drill exist
            79 XS11
            • SFerinTEXAS
              • Jun 2006
              • 877
              seems counter to what I would think. Is that true? Just asking.
              Got a new project with this issue. Need to know.
              79SF
              XJ11
              78E
                • 9980
                The cast is harder than the brass, the bit didn't even make a mark that I can see.
                • tarzan
                  • 1700
                  • Chandler,Az.
                  They are both fairly soft. Brass is more brittle. Aluminum is more gummy. It's pretty easy to machine either. So you need to be fairly accurate. Just use the smallest drill you can, then work up from there.
                  80 SG XS1100
                    • 9980
                    Actually it probably doesn't matter that much, your only talking about around 1/16" - 1/32".
                      • 2095
                      Nice find Greg
                      That will work for drilling jets also.
                      Maybe even save a 2:30 trip to the dentist
