Kerker exhaust
    • 7831
    there IS a difference between STOCK exhaust mounts AND the center stand vis-a-vis Standard and Special. Someone had put a Special exhaust on a Standard I had, and the center stand spring was toast after a short while. The after market systems SHOULD play well, but you may still have to play with the center stand, or remove it and just use the bolts as pins when you need to use it.
