High / Low Beam Switch
  • CRXSi90
    • Jun 2004
    • 400
    • Madison, Wisconsin
    Hi,
    At a time longer ago than I care to think about, my high/low beam switch broke off. It seems others have also had this problem.
    I could and may get an entire replacement handle bar electrical control assembly for $51.00 at Mike's XS or maybe a used unit for less. But I always like a challenge, so I'm wondering if I can machine one. I know some molded parts are impractical to machine.
    My request here is for a picture of that little part inside the switch which breaks. It's going to be a while until I can get back with my bike, but I'd like to get my wheels churning on this (no pun intended).
    Thanks,
    Kevin
    '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
    '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
    I'll see if I can take a photo and send it to you. The part is plastic, and has metal that fits on it for the contacts. The part that breaks is usually the plastic part that the black thumb rest screws on. The plastic is VERY BRITTLE after all these years, and the kill switch suffers from the same problem. As ALL the parts will fit from other models, using the XS650 assembly for parts seems to work well. On the Specials, they are an almost exact replacement, with just the connectors needing to be changed.
      • 5073
      I broke one once trying to pry off the grip. Be careful doing that!
      • CRXSi90
        • Jun 2004
        • 400
        Thanks, that would be great. But like skids said, be careful. I don't want you breaking one that is functioning just to get a picture for me. It's find if you start out with one from your parts box that already has the tab broken off.
        • GTalmageNOLA
          • 20
          • Austin, Tx.
          I just went through mine...
          And had to fix the same thing... I removed all the electrical contacts and put both pieces in my ultrasonic cleaner (definitely worth the small investment from Harbor Freight...) and actually used superglue to repair it before putting it all back together... Mine was a pretty clean break, so there was really good contact. I don't know how long it'll hold up, but I gave it a pretty brisk switching and it seemed pretty sturdy. I also know of a guy on here who posted a thread about replacing the switch assembly with one from an R6 (super readily available for about $20 in good shape) and has a good picture of how all the wires hook up... I'll try to find the link he posted...
          81 XS11
          • GTalmageNOLA
            • 20
            • Austin, Tx.
            The link in question
            It goes without saying that if you want the bike to be stock, this isn't for you, but I'm doing mine cafe style anyhow and so this idea is my next stop if/when that piece breaks again...
            81 XS11
              • 3373
              I second the idea to get one from MikesXS and use the internals to repair your switch. Did that on my 80SG when the hi/lo beam switch cracked internally. Then you have more part for other stuff down the road in most cases.
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
              • CRXSi90
                • Jun 2004
                • 400
                Thanks for the link to the R6 control. I do like the lower cost of the replacement, and the fact that it's newer parts.
                I get that if I value my time, I would just get the Mike's XS control, install it or swap the parts I need, and move on. But it irks me that so many people have to get the whole control or do a retrofit to get their hi/lo functionality back. I was just trying to see if it was feasible for me to make the part and fix what's broken. Ya know, if it ain't broke, don't fix it. If/when I do this, I'd probably make a couple dozen to hand out. Just searching for a bit of info so I can contemplate it and work out the details until I get a chance to go visit my bike in storage..............
                  • 2104
                  A Bit of Info
                  Here Ya Go !!!
                  If Ya need any more LMK HTH
                    • 2104
                    More Pics
                    Thought Ya might need these also.
                    The screw hole is a #36 bit size or in between 3/32" and 7/64"
                    • CRXSi90
                      • Jun 2004
                      • 400
                      That's fantastic! A couple questions...
                      Is the pocket where the 2- and 3- point contacts sit rectangular with sharp corners? That would be difficult to make with a conventional rotating cutter, but maybe it could work by notching out the corner or modifying the copper contacts.
                      Is the ball pressed into place, or is it floating?
                        • 2104
                        Yes, square corners on the recesses.
                        The ball floats in a tapered hole which is a #7 drill bit size, on the contact side, to a #14 on the ball side which retains the ball, which is drilled thru.
                        The small recess is drilled with the #7 bit size also BUT not all the way thru, as can be deducted from the measurements given.
                        Some pics:
                        • CRXSi90
                          • Jun 2004
                          • 400
                          Thanks, I took a first pass at putting together a CAD model/drawing. I have to go back and review some of the pictures and think through their design intent because I know there are details I haven't captured correctly. I'll try to post a screen shot when I can get into my photobucket account.
                          Kevin
                            • 2104
                            Sounds good Kevin, if I can be of assistance, LMK
                            I apologize for the blurry pics, if ya need any clearer LMK.
                            • CRXSi90
                              • Jun 2004
                              • 400
                              preliminary CAD work...
                              I'll probably want you to review this at some point to see if I didn't accurately represent anything, but I can probably take it a little bit further.
