Swingarm removal
  • Roadman48
    • Apr 2012
    • 39
    • Central Ohio
    Swingarm removal
    Hello All,
    I am in the process of replacing the middle drive boot on my XS1100F. Could someone tell me the correct size of the swingarm pivot bolt locknut?
    I need to purchase a socket to remove it and this will save multiple trips to the hardware store.
    Thanks.
    Larry
    Larry
    1979 XS1100SF
    1981 XJ650 Maxim
    1981 XS650 (Frame off rebuild/mild custom)
    1981 SR500 (Pristine Stock Original)
    1979 XT500 (Configured as a TT500)
    2008 HD Sportster (With Texas Ranger sidecar)
    1967 Honda 305 Scrambler (Frame off restoration)
    1966 Honda S90 (Frame off restoration/My first bike)
    • 2104
    27mm or use a 1 1/16" socket HTH
    • Roadman48
      • Apr 2012
      • 39
      • Central Ohio
      Thanks for the quick reply, I really appreciate it.
      Larry
      Larry
      1979 XS1100SF
      1981 XJ650 Maxim
        Larry
        Hi Larry,
        the 27mm (or 1-1/16", they are just about the same size) socket will also fit the rear axle nut and several other fasteners on the bike.
        Sure beats rounding the corners off with a crescent wrench.
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          Hi Larry,
          LOL. Fred, it sounds like you have your anal out, too.
          "about the same size"?
          From the on line conversion site,
          "27 millimeter = 1.062 992 126 inch"
          Lets see, rounding off to the 4th decimal, which rounds off to the 3rd decimal, gets us to 1.063, which is .005 larger than .0625. (1/16th. Actually, to be more anal about it, 27mm is only .0004912 inch larger than 1 & 1/16. Half a thou larger, rounded off.) Close enough for Gummit work.
          Yep, about the same size.
          CZ
            • 3193
            CZ yer a bit to anal about your replies...
            • CaptonZap
              • Jun 2010
              • 1748
              • Denver
              Well, yeah, maybe I do tend to over anal ize things.
              CZ
