Which side for petcocks?
    • 3216
    Rebuilding petcocks on my project 80G. All the parts went into the cleaner from both petcocks. I didn't note which petcock body is for which side (left/right) of the tank, or which lever goes with the correct body.
    I think with the lever in the down position, the curved cutout in the back of the lever piece will expose the side and bottom hole in the petcock body. Correct? If so, then I'm just needin' some guidance on the petcock body.
    I notice the fuel screen tower is offset toward one end of each petcock. Maybe that is the key to knowing which petcock goes on which side, like the petcock goes in the hole so the tower is closer to the front or back of the tank.
    I swear I did a search, and found nada, otherwise I would not be bothering you gents on this fine night.
    ZRX1200
    On the Special model petcocks, they have an L and an R stamped into the bodies, and the levers.
    On the SG I recently aquired, I found they were assembled incorrectly, the left side lever in the right side body. Which made ON actually PRIME. I was with the PO on a long ride when he ran the tank dry in the ON position, no reserve. Don't do that. If we had not been together he would have had a LONG fricken walk!
      Hi Howard,
      While |I do not have the whole answer. When installed the lever
      Points Down for Run
      Points Forward for Reserve ( to go forward in search of gas station
      Points Back for Prime
      Prime position Opens the diapraghm mechanically while the other positions rely on Vacuum.
      Hope that helps you to figure out how to re assemble
      • Laptop_geek
        • Nov 2011
        • 135
        • Memphis, TENN.
        On both of my standard petcocks they are marked L and R on the back of the body. Might check to see if you can find that. If not then I'll take a look at mine to see what goes where.
        1979 XS1100
          • 3216
          Thanks guys!
          ZRX1200
            • 3216
            The bodies are not marked L/R, however one back cover is marked "R" (covers were removed for cleaning and rebuild), but I need to know which petcock body is right and which is left as the cover will fit either side.
            The only markings on the petcock bodies are "Mic" on one side as you look at it longways, and "japan" opposite it on the other side as you look at it longways.
            If someone can look at their 80G (or similar) petcock bodies and tell me how the markings are oriented with the petcocks on the bike that will be the ticket.
            Thanks guys!
            ZRX1200
              • 2072
              Here's a pic of the valve handles and the covers from my '80G HTH
                • 3216
                Thanks much, I will be able to use the levers to find the correct alignment with the holes in the petcock body, thus identifying the bodies. 'preciate it.
                ZRX1200
                  • 2072
                  A few more pics
                  I'm a few days from rebuilding my petcocks also so I took these to help.
                  If ya need any more LMK GL
                    • 3216
                    That, by golly, is the holy grail of petcock identification, especially the last few with the parts laid out.
                    I vote to put that as a sticky in the tech tips.
                    Thank you so much!
                    ZRX1200
                      • 2072
                      Omg !!!
                      Absolutely no Thanxs Necessary !!!
                      XS11 + This Forum + My Man Cave = LOVE
                      Oh yah...the Old Lady's Cookin' too
                      • mack
                        • 2411
                        • Ontario, Canada
                        Schming
                        Show a picture of you whole gas tank, I'm intriged by your paint and pin stripe combo
                        mack
                        79 XS 1100 SF Special
                        HERMES
                        original owner
                        81 XS 1100 LH MNS
                        SPICA
                        78 XS 11E
                        IOTA
                        https://youtu.be/wB5Jfbp6SUc
                        https://youtu.be/RaI3WYHSuWA
                        Frankford, Ont, Canada
                        613-398-6186
                          • 3216
                          His paint looks like what I have on my 80G, "new ruby red" as Yamaha called it. It's not as common as the silver/grey on most 80G's.
                          ZRX1200
                            • 3216
                            Thanks for the help with the Petcocks. Got them done in a short time tonight, ready to go back on the tank.
                            I used some of the info from the Yamaha vacuum petcock rebuid tutorial, the link is posted in at least one thread in the forum. The main thing the tutorial convinced me to do was polish the critical surfaces of the diaphragm seat and the housing the lever turns in. Plus it has good overall knowledge.
                            ZRX1200
                              Me too. It looks good.
