Steering race/roller bearing kits
  • mack
    • 2411
    • Ontario, Canada
    I haven't ordered one of these before, does anyone know if the plastic cup that sit's between the lower triple tree and the lower tapered bearing included in the kit?
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Mack, that's actually a seal and is part of the OEM bearing. Some of the aftermarket kits come with it, some don't. If you can get yours out without destroying it, they can be swapped onto the 'plain' bearings. Not a huge deal if it's missing, but expect some 'weeping' if it is.
    • mack
      • 2411
      • Ontario, Canada
      Thanx Steve
      Looks to me ,that the only way to get the bearing off w/o damaging the seal is to cut it off with a dremel.
      mack
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      613-398-6186
        I've gotten the bearing/seal off with a cold chisel without totally trashing the seal, but it takes care. Minor damage to the seal won't hurt it, and a bit of sealer on the lower seal face can fix that....
          The All Balls steering bearing kit comes with the lower seal.
          • mack
            • 2411
            • Ontario, Canada
            Removal
            I'm going to try to get the old one off today, not much room between the lower tree and the seal face to stick some thing in there to protect the seal but I'll see what I can come up with. Phil do you have a number and source for the All balls kits?
            mack
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            613-398-6186
              Kit available at Dennis Kirk....
              https://www.denniskirk.com/all-balls...prd/121424.sku
              EBay Canada also has them listed under XS1100 steering bearing.
              22-1004 is the All Balls kit number.
              The way I remove that lower bearing is to first cut the bearing cage off with a pair of dykes and remove the roller bearings. The inner race has a prominent lip on the top which makes a great place for a bearing separator to hook onto. Using a harmonic balancer puller and 2 long bolts or all thread, the race can be pulled off cleanly, saving the seal which is underneath.
              • mack
                • 2411
                • Ontario, Canada
                Races
                I thought new races would have been included with the kits?
                mack
                HERMES
                original owner
                81 XS 1100 LH MNS
                SPICA
                78 XS 11E
                IOTA
                613-398-6186
                  They are, it's just not obvious in the pic....
