voltage regulator
  • XS1100_OEM4ME
    • Mar 2009
    • 1619
    • Fort Myers, Florida
    Fluk
    Could of been a fluk, but I bought one for 100+ bucks batt's and accadently left me bike in park with the tail light on. When I tried to recharge my high dollar batt, it was dead and no hope to fix, so I bought a cheap Walmart for 50 bucks and working fine ever since
    1980 XS1100 Special
    1990 V Max
    1982 KZ750 LTD Twin
    1974 CB750-Four
    Past/pres Car's
      Hey us Florida boys have to go for a ride one day, I'll ride over to your west side sometime and we can get together.
      • XS1100_OEM4ME
        • Mar 2009
        • 1619
        Ride
        Phil, I am in. Just give a time and place to meet. It would be cool for us old guys on antique bikes to rool up and order some beers i am in, any time
        1980 XS1100 Special
        1990 V Max
        1982 KZ750 LTD Twin
        1974 CB750-Four
        Past/pres Car's
          Originally posted by natemoen
          I bought a AGM type battery off ebay for something like 45 buck shipped a bit over a year ago and it worked GREAT all last season, and I expect it to work great again this coming season.
          And it is currently tied into my pickup to keep it going all winter. I have done this for years with batteries and it works great.
          +1.......wet cell lead acid batteries do NOT like to be shelved. They like to be 'used', and battery tenders WILL cut overall life of battery by more than half. Both my ST and XS having digital clocks, and I attribute both bike batteries long life to this, battery being used, even though it is minimal amp draw. Replaced the Interstate battery on the XS last year as it was 7+yrs. old. Still load tested within specs., but with the sulfation over that many years, a cell shorting wouldn't happen unless I was a long way from nowhere. The Exide on the ST is now 7 1/2yrs. old, and after sitting a couple months, started bike up and rode it some today. Starting, could tell battery was down a bit, but system will rectify that. Both those batteries have seen a charger only once, since charging them when new. I see way to many members only getting a couple yrs. use out of their batteries, and I have to wonder why.
          • Prothec
            • Jul 2007
            • 587
            • Fort Myers, FL
            I am using an automotive regulator with radio shack bridge rectifiers on my XJ after looking at the 650 forum. I have yet to consider what it would take to do this on an XS, though. I plan to do this to the 78 when I get to the wiring. I will try to get out and pull the parts and take some pictures, but have not been motivated enough lately with the cold weather.
            Starting at post #3, the discussion starts about my Reg/Rectifier setup:
            At this point, I have the rectifiers wired differently on recommendation from a friend who knows much more about this than I.
            I'm using a different regulator from O'Reilly Auto Parts, with an unpainted enclosure (first one from NAPA didn't work, or I fried it). The rectifiers are now epoxied to the inside of an aluminum enclosure instead of bolted to a heatsink. And, like I mentioned earlier, the rectifiers are wired up differently now.
            Website/Blog
              Originally posted by Prothec
              I am using an automotive regulator with radio shack bridge rectifiers on my XJ after looking at the 650 forum. .
              You know, you can use the rectifier within the OEM unit if only your VR is bad, and just use an "external VR." You don't need the bridge rectifier unless it tests as bad. You need an excited field volt regulator.
