Ebay carb ads
  • Aches n Pains
    • 349
    • Reston, Va.
    Ebay carb ads
    Keep seeing carb ads on eBay and just want to be sure I understand.
    Take this ad:
    http://www.ebay.com/itm/1978-1981-YA...E:B:SS:US:1123
    Looks to me like a set that will fit a 78-79 but not the 80/81.
    Too few orifices on the intake side.
    Anticipates a choke lever on the handlebars.
    Is there anyway that these models will fit an 80/81?
    Thanks,
    Aches n Pains
    1995 KZ100P
    Pods, jets, pipes, cam adjuster, oil cooler
    1977 Ironhead - custom build
    Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
    Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
    Yep, a set of '78-79 carbs. These will work fine on the '80-81 bikes, you'll just need to drill the hose nipples on the factory airbox for the bowl vents.
    Don't forget that jetting follows the carb, not the bike....
    • mack
      • 2411
      • Ontario, Canada
      That
      Is a good price, I'd still clean them though before I mounted them.
      mack
      79 XS 1100 SF Special
      HERMES
      original owner
      81 XS 1100 LH MNS
      SPICA
      78 XS 11E
      IOTA
      https://youtu.be/wB5Jfbp6SUc
      https://youtu.be/RaI3WYHSuWA
      Frankford, Ont, Canada
      613-398-6186
      • hamjam
        • 1003
        • Toronto ontario Canada
        the choke lever is already there
        Seamus Ó hUrmholtaigh
        Niimi Moozhwaagan
        NOTICE: No trees were destroyed in the sending of this message. We do concede, however, that a significant number of electrons may have been inconvenienced.
        Any connection between your reality and mine is purely coincidental.
        Member of "FOXS-11" (Former Owner of XS-11)
        and SOXS
        2008 Nomad "Deja Buick'
        • Aches n Pains
          • 349
          • Reston, Va.
          Sorry, HamJam, I meant that the 80/81 carbs anticipate/use a bar mounted choke lever.
          1995 KZ100P
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            The 80/81 carb also have the choke lever on the left side of the carb bank.
            I believe the 82 XJ carbs are cable operated and have a handlebar lever, but I'm not sure on that.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • Jerry
              XS & TRUE XJ GURU
              • 3023
              • Elma, IA.
              That is correct...the XJ has a choke cable mounted on the left handlebar. There have been threads in the past about converting back and forth between lever and cable operation; it is not that big a deal if I recall correctly but have never done it myself.
              Jerry Fields
              '82 XJ 'Sojourn'
              '06 Concours
              My Galleries Page.
              My Blog Page.
              • Aches n Pains
                • 349
                • Reston, Va.
                Thanks, guys. You learn something new every day.
                1995 KZ100P
                  It's not a BIG deal, but there is some monkey-motion involved. If installing earlier carbs on an XJ, you can just leave the XS linkage in place and remove the cable/lever. If you want to retain the lever, you need to swap the XJ choke linkage onto the XS carbs.
                  Going the other way is a bit more difficult. To install the XS linkage onto the XJ carbs, you need the complete XS linkage (including the two detent balls/springs), and need to drill the holes in the 1 and 4 carb bodies for the detents as well as tap existing holes in body 1 for the lever assembly. There's a few variations on this (you can sometimes do without the detent on the 4 carb, and some have threaded the end of the choke shaft for a knob), but it's not a straight bolt-on.
                  If you lack the XS linkage, installing the XJ cable/lever or something more generic is possible but some minor mods/fab work will be needed...
                  Carb differences here: http://www.xs11.com/forum/showthread.php?t=35964
