drive shaft removal
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    drive shaft removal
    1980 1100 special: after i've peeled back the rubber boot and removed the 4 nuts holding the shaft to the drive are there any other pins/clips/etc. that need to be removed before the shaft can be pulled out? neither the oem nor clymers repair manuals specify.thanks for the help
    The front driveshaft splines are held into the u-joint by a compressed internal clip. It will pop loose by itself and remain on the driveshaft when pulling the shaft rearward.
      Part # 36 below...
      • 650mark
        • Jul 2012
        • 307
        • Mesa, Az.
        thanks for the help guys. does the spring clip reseat itself when the shaft is pushed back in? in other words, can i screw it up?
        • 650mark
          • Jul 2012
          • 307
          • Mesa, Az.
          do i even need to unbolt the u-joint if all i want to do is remove the shaft to lube the front end of it?
            You can install the driveshaft with the clip in it's natural position on the shaft, just tap it back into place, it will re-seat. And no, the U-joint doesn't need to be unbolted/removed to grease the front splines.
            • 650mark
              • Jul 2012
              • 307
              • Mesa, Az.
              thanks, phil
                No problem Mark. Mind you it will be a bit tricky installing the driveshaft, getting the angle of the U-joint exactly straight with one hand while inserting the driveshaft with the other. It helps to look down the swingarm tube with a flashlight to get the U-joint in the correct position. Have a little patience and you will be rewarded, good luck!
                • 650mark
                  • Jul 2012
                  • 307
                  • Mesa, Az.
                  i'll remember that as soon as i can get the shaft out! seems to be stuck in there. there's really no place to grab the rear end of it... does it take a real yank to dislodge it? any clues? anybody?
                    Yes, it takes a good yank, I use a 90 degree hook screwdriver type tool and tapping on the base of the handle rearward to remove it. You could also wrap some good strong wire around it and yank it loose.
                      - - - does it take a real yank to dislodge it? any clues? anybody?
                      Hi Mark,
                      no, a southron can do it too.
                      wrap the rear end spline in a protective cloth, clip a vise-grip on there and give the vise-grip a smack with a hammer.
                      BTW, when you pull the rear drive there's a little spring behind the splineshaft.
                      (part #37) Don't lose it.
                      • 650mark
                        • Jul 2012
                        • 307
                        • Mesa, Az.
                        GOT IT! took a real pull and a grunt, but out it came. lubed it up(the easy part) and now trying to get it back in. i can get it just started, i can feel that its going in as far as the spring clip and i can rotate the shaft and the trans is rotating as well but i can't seem to get it all the way in. does it take a good smack with a deadblow hammer to compress the spring clip or should it just slip right in?
                          If it is partially in the u-joint and the splines are lined up, tap/smack it back in.
                          • 650mark
                            • Jul 2012
                            • 307
                            • Mesa, Az.
                            GOT IT AGAIN! just took a little more of a smack than i was using. all back together again and good for a long time now. thanks again for the help guys.
