help with hardware
  • dingman29
    • Sep 2008
    • 52
    • Rock Falls, IL
    a few things today
    #1: are these collar and shaft collar from the rear wheel?? #3&4 on p215 in clymer?? used the cap to help with size...
    #2:
    Hi Dogg,
    I suspect you are seeing a trial installation photo. The headlight ears should have a chromed ring and a Tetraseal (square o-ring) top and bottom to keep them centred on the fork tubes. Hopefully Chris has those parts.
    should there be 2 or 4 chrome rings... i found 2...
    i'm thinking rubber, yamaha plate, rubber, headlight ear, rubber, chrome ring, tree clamp??
    #3: My dad has access to a bead blaster at work, so i had him hit a few parts with it (brake pedal, shifter, pass pegs, misc hardware)... should i be worried about the rust showing up quickly?? should i seal it with clear coat??
    #4: also,
    i have a brand new 130-90-16 tire i was going to use on a honda, but never did... anybody see any problems using this on the rear??
    thanks everybody for the help... really appreciate it...
    chris
    Chris
    twitter.com/thechrisdemon -- instagram.com/chrisdemon
    2012 HD FXDC -- bone stock... for now...
    1980 XS1100 Special --
    under restoration for brother
    2010 HD XL1200 -- good riddance...
    1981 KZ650 CSR -- Found a good/new Home
    1980 CX500 -- livin' it up in FL
      What you appear to have is the dust cover/spacer all in one piece for an XS11 rear wheel on a Special I believe. The other may well be for a Standard or the Front wheel.
      What I have found and been able to make fit is this order, Fork cover..Rubber bushing....Headlight brackets.....chrome ring...top tree.
      As to the rust issue, should not be that quick, but a shot of clear would not hurt.
      The tire will fit fine on the rim. The real issue is how old the tire is, they have a "born on" date stamped into the tire, if it is over 5 years old, most folks suggest replacement.
