fuel petcock o-rings
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    1980 xs1100 special, stock fuel tank with original petcocks. getting ready to have tank repainted and i want to have new o-rings for the petcocks. "obsolete" according to yamaha. will any other part number from yamaha work? any other source? thanks
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    i should have been more specific. i want the tank-to-tap o-ring.
      Those seals come in petcock rebuild kits. If you have a good hardware or auto parts store, they can match it up for you.
      Part number 2W6-24512-00-00 is available. Yamaha Parts House has them for $2.95 each.
      Items 15-28
        Items 15-28
        • 650mark
          • Jul 2012
          • 307
          • Mesa, Az.
          thanks for the help
          • CaptonZap
            • Jun 2010
            • 1748
            • Denver
            A word of caution.
            The originals had two cross links that encased the holes for the bolts. A regular O ring does not provide that bit of sealing, so make sure that you use the gasketedbolts that were originally used to hold the taps in. A dab of gasket sealer on their mating faces before installation would not hurt.
            CZ
              On one of my model E's I needed a "gasket" because my old one leaked. I used a regular o-ring for the perimeter and used fiber washers with flanged bolts to prevent leaks down the bolt threads. No leaks. Never replaced it with OEM style.
                • 8962
                IIRC, only the Standard petcocks use that 3 section O-ring, not the Specials. Both models do use those fiber bolt washers though.
                  BikerPhil, you do remember correctly. Specials use a standard o'ring.
                  • brcree
                    • Mar 2010
                    • 388
                    • S.C.
                    O rings....
                    I found some on Ebay for 5 bucks total..........quick mailing as well. Like stated in here......be sure to seal the bolds with a gasget of some kind. I replaced the O ring on my Special and it still leaked.
                    At this time:
                    1985 Goldwing Innr.
                    1976 cb 750 cafe racer
                    2007 vtx 1300
                    81 sx 1100 s h
                    81 sx 400 special
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      If you decide to make gaskets I recommend this stuff. It's white in color and has a very high resistance to gasoline. I always like to keep some around. If you can find it in 1/16" thickness then you can use it on fuel bowls and everything else. It will not harden dry or rot.
                      • Yard Dogg
                        • Mar 2010
                        • 884
                        • Tri-Cities, Wa
                        The stuff I bought was white in color.
