Xs1100 #2.5
  • conquest87tsi
    • Jun 2012
    • 190
    • Jackson, Minn.
    Xs1100 #2.5
    Well yesterday I bought a '79 standard for $400. Same year as my special so thats cool. Thats where the similarities end. Unlike my special this one is going to be a ground up resto.
    It was a bit of a gamble because it didnt run, front caliper and master need rebuild, fork seals shot, exhuast shot, and I forgot my compression gauge. But it had 19k and a beautiful tank so I took it.
    Got it home and ran a compression test, 30psi on #1a and 2. So I squirted a little atf in each cylinder and charged the battery and jumped to 130, 130, 130, 120. So thats good.
    Well now to why I'm posting. I started on the carbs today and have a couple issues. First, the PO put plastic floats in #1 and #2, but 3 and 4 have the correct brass. Also two of the T's fittings rubber is shot.
    Is it best to try to find some brass floats? The other two don't look great, but were not full of fuel. Or should I replace all with plastic and set the floats at 23mm?
    Where do I find the T's? I have never seen them for sale. I remember vaguely seeing someone had made them from brass with o-ring grooves. Is my best bet finding some brass T's and machining them?
    Thanks for reading my as always overly long post and for any help.
    1979 XS1100 SF
    1979 XS750 SF
    Previous Rides:
    1981 KZ650CSR
    2006 VTX 1300C
    1986 Radian 600
    Brass fuel T's, scroll down....
    Brass floats, scroll down...
    • conquest87tsi
      • Jun 2012
      • 190
      • Jackson, Minn.
      Thanks for the links Phil. I think I'll hold off for a slightly less costly alternative. They are priced similarly on partsnmore and ebay.
      I was able to get the bike running with my spare carb set, a coil, and repaired pick-up coil wire. Since I haven't had to fork out any money other than the purchuse thus far, I'd like to keep it this way. Just wish I wss closer to a salvage yard.
      1979 XS1100 SF
      1979 XS750 SF
      Previous Rides:
      1981 KZ650CSR
      2006 VTX 1300C
      1986 Radian 600
        Here is the repair for the fuel T's....
