Dripping oil
  • Crusty Snippets
    • Sep 2010
    • 428
    • Gabriola BC
    Dripping oil
    Yami is dripping oil from the rubber boot area at the rear of the gear box, or front of the drive shaft.
    I am thinking it is the seal on the back of the gearbox. And I assume the engine will need to come out to replace that seal. Or, if it is engine and gear box oil, I can just keep adding oil until next spring and fix it then when I switch bikes.
    Anyone been there done that?
    Yami now stops with new pieces and fluid, in the front brakes. Very exciting.
    Unkle Crusty
    The middle drive unit can be removed with the engine still in the bike and the seal changed with the unit on the bench. That seal is a unique one and you will have to get one from Yamaha, P/N 93101-35085-00. About $9
      That could mean a leak in either the middle drive or final drive; check the fluid level in both. And these don't leak very often, so once you know which is leaking check the bearing play on the offending part.
      The middle drive can be pulled without disturbing the motor. If you find bad bearing(s) in either it or the FD, it's cheaper to replace than rebuild....
        • 3193
        I think the middle drive is the most likely culprit myself as the final drive would have to leak a lot and basically uphill as when the final drive fluid went down the level would not be high enough to get to the boot. Of course there would be some splashing around but I doubt it would make it to that point as the tube the driveshaft is in would hold a lot of oil. Just ask anyone who ever tried to grease that final drive Zerk.
        Which do you have to add oil to? A simple check of the fluid levels should tell you where to look if the leak is apparent at the boot. JAT
        • James England
          • 3039
          • North of England
          I think it's almost sure that it's the middle gearbox seal. As has been said, thick oil doesn't go uphill easily. A quick check on the middle gearbox oil level will show what's what...
          • Crusty Snippets
            • Sep 2010
            • 428
            • Gabriola BC
            Oil leak
            Thank you for the replies.
            I assume then that the rubber boot can be removed with everything intact.
            I have yet to study it closely. Will check oil levels tomorrow.
            Unkle Crusty
