I havent been able to see any of your photos...
ACCT Installed Wrong?
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~ -
You need to pull that breaker plate w/the pickup coils attached to it off to get the centrifugal advance/reluctor shaft out.
That slot in the breaker plate is there for the reluctor pointer to slip through.Greg
I tried searching how to remove the plate, but could not find it. Do I remove the BIG screws, or just the little ones on the plate?1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
I pulled the plate, so the only thing I was looking at was the part u screw the long allen bolt in, with the springs behind it. I cranked the engine and It wobbles slightly . . .1979 XS1100F
If that crank is out enough to cause the damage to your cover, then you should spew oil out that seal. If you do not remove the shaft, it will wobble.Last edited by DGXSER; 06-21-2013, 10:08 AM.Life is what happens while your planning everything else!
78 XS750Comment
Smooth as butter u big lovers of making my life grand u!!! Thank you everyone! However, I have to get ready for work.1979 XS1100F
Be sure and clean and lube those weights on the centrifugal advance so they work freely. Makes a difference on how the engine runs.Greg
COOL!!!
I just knew there was no way in he!! you bent the dang crank on that engine. Glad we sorted it out. Now earn the money to pay for the gallons of gas your gonna burn through that big nasty beast!!
78 XS750Comment
U guys are sooooo great!! A bunch of fathers to me, all of u! Except Nate, u can be my brother, lol.1979 XS1100F
Ummmmmmm..........can I be a favorite uncle? I have too many kids already.
Ummm.....All I am gonna say is don't start holding your hand out asking for gas money and car keys....I got enough of that as is!
78 XS750Comment
that's how she's sitting in the parking lot as I type this. I have a small oil leak from the oil pan (probs gasket not sealing). I'll drain the oil and pull the pan again tomorrow morning. I got the carbs as best as I can get them. I notice a teeny-tiny bog, but I can deal with that. I have to do a petcock re-build, as one is leaking, so I installed some Briggs & Stratton in-line cutoffs. I want to save-up for a fork brace, maybe do an HID conversion, led lights, and a fuse panel upgrade.
Again, thank you fellas for all of your help and support.1979 XS1100F
