ACCT Installed Wrong?
  • WMarshy
    • Apr 2009
    • 2402
    • Mexico NY
    #211
    I havent been able to see any of your photos...
    '79 XS11 F
    Stock except K&N
    '79 XS11 SF
    Stock, no title.
    '84 Chevy K-10 "Big Blue"
      You need to pull that breaker plate w/the pickup coils attached to it off to get the centrifugal advance/reluctor shaft out.
      That slot in the breaker plate is there for the reluctor pointer to slip through.
        I had to look at them in my email notifications Wade.
          • 3952
          I tried searching how to remove the plate, but could not find it. Do I remove the BIG screws, or just the little ones on the plate?
            • 3952
            I pulled the plate, so the only thing I was looking at was the part u screw the long allen bolt in, with the springs behind it. I cranked the engine and It wobbles slightly . . .
              You should be able to pull that off of the end of the crank. It sits down in kind of a recess and there is an alignment pin.
              I have a picture of it somewhere. Let me see if I can find it.
              There, that's what the end of the crank looks like with it removed.
                #217
                If that crank is out enough to cause the damage to your cover, then you should spew oil out that seal. If you do not remove the shaft, it will wobble.
                  This is what the end of the shaft that fits in there looks like. It has to fit down in there perfectly to seat properly.
                    • 3952
                    Smooth as butter u big lovers of making my life grand u!!! Thank you everyone! However, I have to get ready for work.
                      Be sure and clean and lube those weights on the centrifugal advance so they work freely. Makes a difference on how the engine runs.
                        #221
                        COOL!!! I just knew there was no way in he!! you bent the dang crank on that engine. Glad we sorted it out. Now earn the money to pay for the gallons of gas your gonna burn through that big nasty beast!!
                          • 3952
                          U guys are sooooo great!! A bunch of fathers to me, all of u! Except Nate, u can be my brother, lol.
                            Ummmmmmm..........can I be a favorite uncle? I have too many kids already.
                              #224
                              Ummm.....All I am gonna say is don't start holding your hand out asking for gas money and car keys....I got enough of that as is!
                                • 3952
                                that's how she's sitting in the parking lot as I type this. I have a small oil leak from the oil pan (probs gasket not sealing). I'll drain the oil and pull the pan again tomorrow morning. I got the carbs as best as I can get them. I notice a teeny-tiny bog, but I can deal with that. I have to do a petcock re-build, as one is leaking, so I installed some Briggs & Stratton in-line cutoffs. I want to save-up for a fork brace, maybe do an HID conversion, led lights, and a fuse panel upgrade.
                                Again, thank you fellas for all of your help and support.
