Front reservior
  • mack
    • 2411
    • Ontario, Canada
    Front reservior
    Is there a source for a replacement reservior for the E front m/c. Or rear for that matter. Both mine are rotten. They cleaned up ok but the plastic is rotten and flaking
    mack
    79 XS 1100 SF Special
    HERMES
    original owner
    81 XS 1100 LH MNS
    SPICA
    78 XS 11E
    IOTA
    https://youtu.be/wB5Jfbp6SUc
    https://youtu.be/RaI3WYHSuWA
    Frankford, Ont, Canada
    613-398-6186
    Unfortunately, no. You can't even use a later style as they're different. You can swap complete M/Cs though....
    Or you can try this.... http://www.xs11.com/forum/showthread...ight=reservoir
      • 7817
      I did mine as you would a modern plastic headlight lens. I did it as in Steve's link, but I went to maybe 2000 grit to finish. I followed with a clear coat. I used the stuff in a headlight kit because I had it. It doesn't look as new, but the result is very good. It is certainly no longer yellow and chalky.
        • 3918
        U can always swap the MC from one off another XS, such as a 750. I'd go with one from an XJ if I were you. They are nicer looking. I'm tired of that old look. Mine is looking pretty rough too. Fortunately I have an extra that is in much better shape that I'll throw on in the winter when the bike is down due to snow.
        • rs2289
          • Oct 2012
          • 18
          • Drums, PA
          So the XJ750 M/C will work on a '79SF? I need to replace mine on this rebuild, it is completely shot. Any particular year or will anyone do just fine?
          79 SF "Under Construction and in a million pieces"
            Check bore size of the one you want to use. The stock XS11 bore is 11/16", some have gone to a smaller bore but you need to install braided stainless lines if you go that route. A 5/8" bore is acceptable, smaller can be iffy....
            • RWrightPhotog
              • Oct 2012
              • 28
              • Columbus, GA.
              I am installing a complete m/c off of a Yamaha Raptor 660. It's what another member did with good results. It looks pretty good, too. More of a modern looking one. It's a few posts below this one...
              1980 Yamaha XS-Eleven Special
              1982 Jeep Wagoneer
              1989 Nissan 300zx
              My Photography: http://rwrightphotography.blogspot.com
              • mikubuilder
                • Jul 2011
                • 548
                • Westland, Mich.
                like Steve says, bore size is a key, make sure it's from a dual disk front set-up... I got one from a Blaster, all aluminum....I will use it after mine will stop working
                Nick
                1982 Virago 750 (it's alive!)
                • OregonRider
                  • Jun 2010
                  • 33
                  Just saw this on e-bay
                  82' XJ1100 turned "bagger" with Vetter Fairing.
                    • 2075
                    Originally posted by OregonRider
                    Nice, but only a 12.7mm bore which is approx. 1/2" too small for dual discs
                    • lee_dutcher
                      • Apr 2009
                      • 822
                      • mason city iowa
                      Yep raptor 660 mc works great and looks great too..
                      1980 gs1000g "stock"
                      2008 jmstar 150cc Chinese scooter ( wife's bike)
