Throttle cable
  • Jeffintampa
    • Apr 2011
    • 344
    • Zephyrhills, Florida
    Throttle cable
    Hi all,
    My bike was Idleing very low so I adjusted it by the handle bar, looseing the nut and turning the long thing till it sounded like I wanted it to. The issue that came up is when I turn the handle bars it pulls on the throttle cable and reves the engine, I can grab the cable by were it goes behind the headling and move it and the engine revs. what the fix?
    Bike History:1980 XS 1100 special current bike
    1980 XS 850 special wife sold
    • 8930
    The main idle adjustment is in between carbs 2 and 3, below the carb bank on the front side. First, put some slack back in the cable up at the handlebar. Next, adjust the idle speed to your liking with the main idle adjustment thumbwheel at the carbs. Now at the handlebars, take just enough slack out of the cable so there is no change in idle speed when moving the steering from left to right. Got all that?
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Not the place to adjust throttle. There is an adjustment between the carbs a long screw held in tension by a spring. You adjust Idle speed using this. The cable you should route in a path to where it is not pullled or pushed turning the bars. You should have a little slack in the cable when fully returned having it to where turing the bars gives it throttle is dangerous so you need to relocate the throttle cable path to where is has freedom to move.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • Jeffintampa
        • Apr 2011
        • 344
        Thanks I will slacken that on and think I see that thumb screw between the carbs
