Urgent question about rear hub. I think. Maybe.
  • ljasonb
    • Jul 2012
    • 39
    • Charlotte, N.C.
    This is the right side of the rear axle on my XJ. Should there be a pin or bolt through those two holes to lock it? Been riding without. Have I been risking my health and welfare unnecessarily? Thanks experts!!
    82 XJ11
    • 3193
    Nope. No pin in those holes. The pinch bolt that you show is all that is there.
    • buffalo
      • Aug 2002
      • 141
      • Carson City, NV.
      Not positive about this, but I always thought those holes in the axle were to insert a phillips screwdriver through to help pull the axle out when removing. At least that is what I always used them for. Most bikes have them, never saw a bolt in one.
      buffalo
      80 XS1100SG
      • ljasonb
        • Jul 2012
        • 39
        • Charlotte, N.C.
        Excellent. Thanks!!
        82 XJ11
          • 2097
          Correct, and...
          ...to also hold the axle from turning whilst torqueing the axle nut to 108 ft. lbs. BEFORE torqueing the pinch bolt to 14.5 ft. lbs.
          • MPittma100
            • Aug 2011
            • 2359
            Bolt Hole?
            There is a tool in the tool kit that came with the bike if you have it to be used for same.
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
              I always make sure that the pinch bolt is at least snugged, but not tight, when torquing the axle nut. The axle head can spread the flanges if you don't...
                • 2097
                The Head...
                ...of the axle/bolt is and should be approx. 25mm to 26mm in diameter and a straight consistent cylindrical shape that fits into the swing arm just as a piston in the cylinder bore.
                IF your axle/bolt is spreading the split swing arm then the axle/bolt is probably damaged.
                The axle/bolt gets torqued first, with all model respective bearings, bushings and washers in the right places, as the final drive aligns the rear wheel.
                Then the pinch bolt gets torqued to basically hold the axle/bolt from spinning under load.
                  I think I found my problem! The spacer is probably wrong with the G Model. I will post a new thread.
