Having done some night riding of late, and having a stock reg/ rect and a stock headlight. I determined I was long overdue for an upgrade. Having tried the typical H4 Bi-Xenon light and been very impressed with the light output but not the dazzling or blinding effect on on-coming traffic, I followed TCs thread on the HID project closely. So MAD PROPS to the true doctor, TC who came up with this assembly.
So here is my coverage of the implementation of that upgrade. Many thanks to TC for doing all the leg work to determine the products and how to implement them. I am simply trying to provide a little more detail into how I got the project completed.
Step one, get the 7” Round projector housing. It is listed on ebay as “H6024 7" ROUND DIAMOND CUT PROJECTOR HEADLIGHTS W/H4 HEAD LIGHTS LAMP PAIR SET” Sellers name is X3RACING. You will only use the housing of this, not the bulb or the internal lens.
The above assembly is after removing the bulb that comes with the assembly. Now you want to remove the glass lens from the housing. Now, I tried this by prying on the thinner lip that is exposed, and my first lens cracked all over the place. So, I took a hacksaw and cut a notch out of the outer lip in the grey plastic to let me get under the thicker lip of the glass lens.
As you can see, this allowed me to put the needed pressure on the glass to pry it out without damaging it.
So now you can turn the assembly over and remove all the attachments, the internal optic lens held in place with two screws, and the hardware to secure the bulb. Total of four small screws.
After removing the hardware, you now have an empty shell of a projector lens and a glass lens cover. I left in the “angel eye” just in case I decide to try it.
So now you’re ready for the mini projector HID kit. This is sold by MTFANSCLUB and listed as “2.5" MOTORCYCLE BI-XENON HID KIT Angel Eye Devil Eye Projector Lens Ballast”. Make sure you get the kit with the ballast! It is sold with and without the ballast.
Here is the contents.
The HID projector is pre-assembled as shown. You will need to disassemble this, start by removing the small screw and clip (green arrow) on the back that holds the bulb in. Then unscrew the black retaining nut (red arrow) and the rest of the components can be removed. Note, if you do not remove the clip that retains the bulb, the black retaining nut can not come off.
Dis-assembled.
So now you have the washers shown above. The white silicone washer on the left is thick and it goes on the projector bulb housing inside the 7” Round housing. At stock thickness, the glass lens will not fit over the 2.5” HID assembly. You will need to cut the silicone washer down, roughly in half. I used my handy dandy pocket knife to cut it.
Below you see the two pieces after cutting.
Now you put the thinner silicone washer, with the smaller opening, back onto the HID assembly, larger opening side against the housing as before. Then slide the tail shaft through the 7” housing. Now put the remaining washers back on. You will note that the larger metal washers have tabs that position them in slots in the tail shaft. The largest also has the three tabs that will fit only one way into the 7” housing.
For those of you who are keeping the angel / devil eye wiring in place, you will notice that there is a small notch in the bottom of the 7” housing to allow the wires to pass, but the silicone and metal washers cover that opening. I took my handy dandy pocket knife and cut a slot in the silicone washer for the wires to slip through.
I then cut a notch out of the large metal washer with a dremel cutoff wheel to make room for the wires. Sorry the pic is a little blury.
Now you’re ready for final assembly . Notice that there is a slot in the bottom of the tail shaft where the low/hi beam part of the HID bulb goes. This MUST face down for proper low and hi beam operation. You will note it needed adjustment in the picture above. Below you see the full assembly beside a stock headlight for comparison on depth/height. All that is left is to permanently re-attach the glass lens to the 7” housing.
I took some 3M body moulding double sided outdoor tape and cut it into thin strips to reattach the lens. I laid the thin strips into the lip inside the housing and then pushed the lens into the tape.
Below you see the new HID assembly installed in the headlight trim brackets, ready to be installed in the headlight bucket. It is pretty simple to disassemble and reassemble. There are two bolts, one on top and one on bottom that hold the internal shell in the larger trim ring. Then three screws attach the inner shell around the actual light.
TO BE CONTINUED.......
Dis-assembled.
