Nedle jet/nozzle main
  • ronpelfrey
    • Oct 2012
    • 4
    • Brantford, Ontario, Canada
    Good-Day
    Had a 1980 XS110SG given to me and my son to restore/ practice work on. We've hit a major snafu. I wrecked one of the needle jets trying to remove. Yamaha & no after market suppliers even offer that part any longer. Removed the other 3 no problem once we found out the easy and right way to do. ( we trying to follow the repair manual) I believe we can get the bike to run if we can find a new needle jet and get the carbs back on the bike. Can any one spare one or know where I could find one. I have spent hours on line searching with no luck. I see there is going to be a lot of helpful information on this site, hope to use it often. Thanks for your replies.
    Ron
    p.s. when I say spare I mean sell me one.
    80 SG
    • 5055
    Yeah the clymers manual is bad. It says to pull the nozzle with needle nose pliars (or something like that). Can you believe that? The horror!
    • ronpelfrey
      • Oct 2012
      • 4
      I know that's exactly what I tried and broke the half shroud off, the other three once I took the washer out off the bottom of the tube i was abble to easily use a punch and get the other out damaged free. Now to find a replacement. Any suggestions?
      Pelf
      80 SG
        • 8709
        It would be helpful if you tell us the number stamped on the side of the emulsion tube, this way it will be easier for folks to look thru their parts box to try to find one for you.
          Ok, so you are looking for the emulsion tube, I thought you were looking for the meeting needle. As Phil said, we need the number off if it. There are several different versions, and there is no grantee you have the original carbs or the original tubes.
          • WMarshy
            • Apr 2009
            • 2402
            • Mexico NY
            I have a source that can CNC some new nozzles. I just need a good example to take measurements from... Is this anyone is interested in?
            Im not sure how many variations there are but I have ones from my '79F I could use, could anyone loan out the other types?
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
              • 8709
              Ron, if you have the original correct carbs on your 80 Special, you should need an emultion tube marked X-2.
                Phil, that doesn't help. Yamaha identifies all of the XS/XJ emulsion tubes as 'X-2' but there are variations in the number/location of holes in the actual tubes between models. Maybe it's not supposed to make any difference, but if it does you could be chasing your tail with tuning issues. Look here: http://www.xs11.com/forum/showthread.php?t=382 for a pic of different versions....
                  • 8709
                  Yep Steve you are correct, the X-2 is just the style of tube, there is another number stamped on them.
                  • mack
                    • 2411
                    • Ontario, Canada
                    I'm pretty close to you
                    I think I have some spares but as stated, we need the number. It should be 300 X2 for yours I believe.
                    mack
                    79 XS 1100 SF Special
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    https://youtu.be/wB5Jfbp6SUc
                    https://youtu.be/RaI3WYHSuWA
                    Frankford, Ont, Canada
                    613-398-6186
