New XS11 to ride!!!!
    • 4015
    Hey Fellas-
    So, finally saved my pennies and was able to pick up the XS11 today. 1979 Standard. Painted in Dynamite Yellow. About 30,000 well-maintained miles on her (all documented with original bill of sale included). I am the third owner, with the previous owner owning the bike since '91. He completely went through the bike's engine and rebuilt it from the bottom up, including dog gear fix. Had the valves surfaced and the intake ported. The only non-standard on the bike is that he converted the air filter box to accommodate an automotive square filter (pretty nice in my book), and Mac pipes, which surprisingly sound much better on this bike than they did on my 750. He gave me three boxes of invaluable parts including extra electronics, side covers, etc. On his wall he had a complete set of Jardine spaghetti pipes that he was going to give me. I felt obliged to tell him that he could fetch some good money for them on this forum, and that he was better off selling them, as I felt like a crook taking them off his hands.
    The first thing I am going to do today is first FIGURE OUT HOW TO GET THE SEAT AND LEFT SIDE COVER OFF (HELP IS APPRECIATED). After that, change the oil, throw on some Euro bars, and after this weekend order an ACCT and a TKAT fork brace. Bike runs good. Gotta be honest, I was expecting a little bit more hold onto your seat power, but, that may be a jetting issue in-combination with the exhaust. We'll see. I'll check on the valve lash when I have a day off soon.
    Brand new Metzeler touring tired on them. All the chrome looks great. Plan is to clean up the engine and re-paint it. Not sure if I'll go gray or black. We'll see. Other than that, I am happy with the bike and cannot wait to have the whole next summer to spend on the road with her.
  • tarzan
    • 1700
    • Chandler,Az.
    Wheres the pics?
    To remove the seat there are two bolts under it,one on each side. loosen both bolts and slide the seat forward and lift straight up.
    The left side cover has a lock at the bottom. Insert your key and turn, then pull out on the bottom.Once the bottom is free, pull the top of the cover.The top has two rubber grommets that hold it in place.
    80 SG XS1100
    14 Victory Cross Country
      • 4015
      Pictures will come tonight after work. I'm actually off to the mall to pick up a few things, then Walmart for some Rotella, then Advance for a caliber lock, then the motorcycle shop for some Euro bars.
        • 4015
        And thanks for the info on removing the seat.
        • ESJr1642
          • Jan 2012
          • 103
          • Groveland, FL
          Congrats!
          Congrats on the purchase! Looking forward to seeing some pics. Maybe a 2013 ride early next year as I am near you..
          1979 XS110F, Stock
          1980 XS1100G, Mostly Stock, gifted to my son.
          2000 YZ 250, Sold
          2002 YZ125, Sold
          2009 Royal Star Venture
          '94 Pontiac Trans Am, 25th Anniversary, For Sale
          Ernie
            Rotella will cause your clutch to slip. Just sayin'
              Originally posted by tarzan
              Wheres the pics?
              The locking tab is formed plastic and somewhat delicate. The key only goes part way in to unlock the cover.
                • 4015
                  • 3193
                  Nice looking ride! That yellow is dynamite for sure. You are at the right place to keep it well maintained and running great as so many here are willing to share their knowledge. Happy trails.
                    Nice lookin' F Ian. I like the way the Mac turnouts sound too, they have a nice growl.
                    Man, I can't believe you didn't snap up that set of Jardines.
                    I would like to see the air filter conversion when yo get a chance.
                      • 4015
                      Y Hmm. Got an oil leak from the oil filter housing I think. Did I tighten it too hard, not enough, or something else? And, I'll get a pic of that air filter set-up tonight.
                        • 4015
                        Does the oil filter bolt spring go on the inside or the outside of the filter? Right now it's on the outside, and if it's supposed to go on the inside, I have the source of my leak.
                          • 4015
                          Regarding the Jardines, they were in good shape. He said he was going to throw them away. He said they were too loud for him. I don't like loud pipes either.
                            I think I just choked on my tongue.
                              Insert the bolt into the cup. Drop the spring in around the bolt. Put the washer onto the spring. Then the filter. The oring aroung the bolt is the seal and it seals regarless of the bolt torque. The trick is to be sure the big oring is in the groove when you tighten the cup with the bolt. New ones need to be put into a pan of hot water to straighten out. A bit of grease will help hold it in the groove of the cup. If it leaks, it is likely that the Oring slipped out of the groove. Do not over-torque the bolt or you will play hell getting it loose for the next oil change!!!
