Non-runner picked up for 450. I was told it had a leaking carb, bad wiring, and a fried starter. Title was never transferred so I hunted down the original seller and was told it had a bad cylinder as well.
Not sure what it will look like when finished, but here's a rundown.
Lists will be updated as time goes on
Known Issues:
Not currently running, compression test is not bad though
Cylinder 3 needs to be helicoiled.
Wiring harness needs to be gone through
Missing center stand
Missing spring on kickstand
Missing gas tank bolt
Missing air cleaner
Missing tool box
Missing Octopus (4 gas lines currently run to carbs)
Left switches have broken high/low switch
Right switches have broken run/stop switch
Turn signals are dead
Brakes are sticking (but work)
Semi-Issues:
Seat needs to be recovered
Headlight is probably from a windjammer as the bucket is labeled Vetter
Headlight installed at an angle
Aftermarket turn signals need to be replaced
Front-end is air assist
Fuse block was replaced with inlines
I think the pipes have been cut and mufflers replaced (unsure of replacement used)
Tank has semi-bad bondo job to debrand it
Non-Issues:
Hunted down original owner, so title will not be an issue
Starter works fine
Kickstart works as well
Tail and brake light work
Headlight works, but needs some work
non-stock handlebars.. Not sure if I want to keep them, but they aren't bad
Stuff done so far:
Lubed ignition switch and fork lock
Tightened battery ground
Used another battery to revive dead (0.03vdc) agm battery
Compression test
Tested brake and tail light
Tested headlight
Tested starter
Removed the makeshift (tape/foam/boot) air filters
Plugged the carburetors since it's been raining
Here are a few pics.
Known Issues:
Missing air cleaner
Missing tool box
Semi-Issues:
Non-Issues:
Starter works fine
Stuff done so far:
Compression test
Tested headlight
Tested starter
