Dead Bike
  • MPittma100
    • Aug 2011
    • 2359
    Charging?
    If you have no evidence that the battery is being charged by the alternator (at a high idle), check the muti-conductor connector at the
    regulator/rectifier - specfically the larger guage wire. Look carefully for corroded terminal blades inside the connector or for evidence of a burned wire.
    If something is damaged needing replacement inside the connector, you can cut the affected wires and reconnect them outside of the plastic connector.
    When checking the battery/chassis grounds, improve them by adding another cable betwen them so as to have them being grounded directly to the battery (and chassis). Chassis grounds are poor grounds.
    MP
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
