To fog or not?
  • Filter
  • To fog or not?
    I am getting ready to store for a NNY winter. Is fogging the engine worth the effort? Better running through some Seafoam? What are your thoughts. Thanks, Jon
    1979 XS1100 Special
    1965 T125 Triumph Custom Chopper
  • #2
    It won't hurt anything.
    • #3
      If it's in your budget do both and throw in a oil change too. Lube your cables clean/check you connectors now and in the spring.
      BDF Special
      • #4
        Runnin' through SeaFoam could be hazardous, but half a can and full tank of fuel riding a few miles first would work.
        • #5
          Just pull the plugs, pour a tablespoon of 10w30 in the holes and crank it over with the plugs out. Reinstall plugs and you are done as far as cylinder storage prep.
          I'm draggin my '78 back into the living room this winter. Can fix and watch Netflix at the same time.
          WIN!
          1) Fire up Internet Explorer
          2) http://www.yahoo.com
          3) type "www.mapquest.com" into the Yahoo search page.
          4) go about day as VP managing multi-million dollar financial contracts.
          • #6
            Im kinda neutral on fogging the motor... mose people use it on 2-strokes but there's no reason you can't use it on the bike. Just follow the directions if you decide to use it. It's not a bad idea if your going to store your bike outside. See other comments about winterizing here...
            http://www.xs11.com/forum/showthread.php?t=38254
            '79 XS11 F
            Stock except K&N
            '79 XS11 SF
            Stock, no title.
            '84 Chevy K-10 "Big Blue"
