need help in San Diego area.
  • BNorton
    • Jun 2012
    • 15
    • San Diego, Ca.
    I need help with the electrical aspect of my '80 XS11G project. I'm in the San Diego area. Can anyone help?
    80 XS11
  • trdriver71
    • 360
    • Edmonton Alberta
    Can you post what electrical problems you are having so we can give you some help.
    '79 XS11SF
    • BNorton
      • Jun 2012
      • 15
      • San Diego, Ca.
      i can jump across the starter solenoid and start the bike but the ignition and starter button do nothing (unless i use the start button to jump the solenoid). I had the neutral light then i didn't then I did and now i don't. the lights and horn don't work either. I think it might be the actual switches but i cant verify that. a lot of things were modified before i got the bike
      80 XS11
        • 5061
        Filthy key switch contacts? Might be a good place to start trouble shooting...
          If the harness has been badly hacked, troubleshooting can be extremely tough. Has the wiring ever worked since you got the bike, or is this a new problem? Do you still have the original fusebox? The fact that you have more than one circuit malfunctioning makes me think the problem is between the battery and the fusebox (main power feed), or maybe the fusebox. You might start here: http://www.xs11.com/forum/showthread.php?t=35337 and start tracing and see what you can find...
          • GARTHXS
            • 1631
            • Seattle
            Where do you live in SD . I might be able to help . Until then try to download the wiring schematic for your bike or I can send you one . It says you have an 80 right is it a special or standard?
            91 kwaka kz1000p
            Stock
            ( Insert clever quote here )
            • BNorton
              • Jun 2012
              • 15
              • San Diego, Ca.
              I'm in Chula Vista right off the 805. the ignition was engaging the electrical system. The neutral Light came on when I turned it on, then the light went away. I have the manual printed out with all of the diagrams and everything. I think it's a standard. I'm not sure though.
              80 XS11
              • GARTHXS
                • 1631
                • Seattle
                Easy way to check is see if the vin starts with 2h7
                91 kwaka kz1000p
                Stock
                • BNorton
                  • Jun 2012
                  • 15
                  • San Diego, Ca.
                  vin starts with 3h5
                  80 XS11
                  • GARTHXS
                    • 1631
                    • Seattle
                    I believe you have an 80 g standard
                    91 kwaka kz1000p
                    Stock
                    • GARTHXS
                      • 1631
                      • Seattle
                      Can you post some pics of your electrical . Fuse box and inside the headlights bucket
                      91 kwaka kz1000p
                      Stock
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        Study this, http://http://farm5.static.flickr.co...1ae5cbd4_o.gifuntil you have it memorized, or at least until you can find a component on the schematic as well as the bike.
                        Then put a jumper across the fuse terminals of the rearmost fuse, and see if anything improves. That's the red/wht and brown wires, at the fuse block. CZ
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Believe it or not
                          Check the grounds for good connection. Factory ground straps are from negative battery terminal to chassis and engine to chassis. These leave room for improvement compared to a direct battery ground to the components.
                          In the XS11/XJ11 Discussion (forums) see the thread "Believe it or not" for better component grounding.
                          MP
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          Stebel Nautilus Horn
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                          • GARTHXS
                            • 1631
                            • Seattle
                            Pm me your number I'm off wed day I might be able to swing by , do you have a voltage meter ?
                            91 kwaka kz1000p
                            Stock
