Wont start when cold
    • 5057
    PS. The enrichener may be plugged in the float bowl bottoms (common problem).
      Have you changed the oil to a winter visocity? 20W50 is way too thick for temps that cold. It will lug the engine down and make it hard to start.
      • Tat2demon
        • Jun 2012
        • 718
        • Sioux Falls, South Dakota
        Originally posted by DGXSER
        Does it use enrichment circuit to start in warmer weather? I use full choke to start year round.
        I use it after it starts just to keep the RPMs up a little until the motor warms up.
        Originally posted by skids
        Check to see if the airbox has gasoline in it. It will seem flooded if the petcock or octopus and fuel valves in the carbs are leaking.
        None in the box.
        Will check that out if I cant figure out anything else without taking the carbs apart again.
        No I havent. Never thought about it. What do you suggest?
        Nate
        78 XS11 "Matilda" 2H7 000364
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
        • CaptonZap
          • Jun 2010
          • 1748
          • Denver
          Your best bet would be to get, or download, a manual, which gives you all the information that you are seeking.
          CZ
            'Bug is right; when temps get to 40 or less, Yamaha recommends switching to a 10W-40 oil. The only caveat to this is if you have a big temp swing during the day; they don't recommend this weight if temps are above 60F.
            You might also try putting a cover over the bike and putting a light under it to help keep the bike warm...
              I have not yet switched oil from 20W50 to 10W40 on mine over the winter. Now I do not ride every day or often at all below 50 deg outside. But I have started and ridden in 30-40 deg weather without the engine fighting me at all on start-up. But then, mine is in an enclosed but unheated garage.
                I have not switched oils yet this year and when I start it up in the morning from the garage when it has been in the 20's-30's it starts just fine, but when I start it after work and it has been outside all day and it Is In the 30's-40's then it is a little more difficult!
                • Tat2demon
                  • Jun 2012
                  • 718
                  Just changed out the oil. Will see how it is tomorrow. Today it was 50 when I went to work and it started just fine. It was 42 by the time I got off and wouldnt start. I waited a few hours for it to hit 48 and it fired right off.
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
