Question for you late carb gurus
    • 9981
    Originally posted by natemoen
    Most of the later carbs don't even use that rubber plug so that usually is not an Issue, only the first part of the '80 model year used that plug.
    The brass tube IS the true issue.
    Which brass tube?
      Originally posted by BA80
      Which brass tube?
      The enrichment circuit tube that goes down into the bowl.
        • 9981
        Are you going to explain or do we have to play 50 questions?
          Greg, look here: http://www.xs11.com/forum/showthread.php?t=35964 , fifth pic down....
            • 9981
            I understand the differences between the early and late carbs. Is there an issue with THE TUBE other than it being in a different position?
              Same function as far as I know Greg, just in a slightly different place. They moved the hole the tube goes into in the float bowl to match, that's why the bowls won't interchange.
                Just so happens, I have a set of 78-79 carbs where the PO put an 80 carb bowl on one of the carbs. They even bent an offset in the tube to make it match the bowls hole location. However, the bowl would never fully seat to the carb body. It was not visible to see the bowl did not seat completely, but I always had gas dripping out of that bowl from it not sealing properly. A member here was kind enough to send me the right bowl for my use, and with some pliers work to eliminate the offset in the tube, I have a working carb.
                  You asked what tube so I told you what tube! What more did you want from "Which brass tube?"
                    • 9981
                    I didn't think I would have to go into detail to get the LONG answer from you Nate.
                    I was unaware which tube you were speaking of therfore it could be logically deduced that I was unaware what problem you were speaking of.
                    Elementary my dear natemoen.
                      Well them are only 2 "tubes" in the carbs, enrichment circuit tube and emulsion tube. Only one is in the bowle so I guess I just assumed originally.
                      But yes, Steve is correct, the tube is move just slightly (i think it Is closer to the center but cant remember for certain). You can hardly tell by looking at them that there is a difference. I didn't figure out the problem till I measured the distance from the edge.
