Question for you late carb gurus
    • 9980
    I know some of the later carbs have a rubber plug over the pilot jet and some don't. Question is, how do you tell which take the plug and which don't?
    I'm putting Doc's carbs together and there are plugs in the parts but looking at the carbs there is no feed to the pilots. Seems that if they take plugs there would have to be a feed port from the main well and these don't have one.
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    You got it right. If there's no crossover hole from the main to the pilot then no plugs.
    If you did plug it up, then the pilot circuit would get no fuel and you'd know it real quick.
    Vice versa works too, If you do have the crossove hole and leave the plugs out, then the pilot circuit gets way too much fuel and you'll know that too. BTDT.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
      • 9980
      Thanks George. That's what I thought but I wanted to be sure. I've never used the lat carbs because I always thought the early ones better because of being more adjustable.
        Actually having seperate fuel feeds, not being combined the later carbs are more adjustable for each circuit.
          • 9980
          But, no adjustment on the slide needles and the idle mixture screws are a p.i.t.a. to get to.
            metering rod slots......gotta give ya that one........idle mix screws, not so much since hopefully the tank is off for a sync anyways if the mixture screw settings are changed with the 'lean drop' method.......if your hearing is up to snuff.
              • 9980
              I don't need to take the tank off. I can see the screws and adjust them with my 1970's 90º adjusting tool.
              The only thing I don't like is the bowl vent tubes going to the air box, adds to the clutter in there, and the idle can be a bitch to adjust.
                Flat blade screwdriver makes adjusting idle a snap
                  • 3186
                  One thing I have found to be common on all my carbs (which I think most are original) is the small tit located in the later fuel bowl and its absence from the earlier fuel bowls. It is located in a place which would hold in a rubber plug when the bowl was installed. Here are a couple of pics to show you the tit I speak of. I may be wrong but all of the carbs I own with rubber plugs have this small tit in the fuel bowl.
                    • 9980
                    Hmm.....Interesting. I've not heard of that before. Thanks Doug.
                      good 'catch' there Doug! Myself, never messed with the early model XS carbs, but in a nutshell I can see where they would be more 'forgiving' to deal with feeding from both circuits. I can say, if you make so much as a minute change in the later carbs and they don't like it, they will definitely let you know. IMO, maybe not so much from the early carbs, just from the fact they share circuits to a certain extent.
                      • petejw
                        • 2269
                        • sydney australia
                        hey greg,
                        the later carbs on the rh bikes (aus)
                        had adjustable slide needles that u could
                        use with the later special carbs,
                        the later carbs are also better designed to run pods
                        and the mixture screw tips dont break off either. :-)
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                          • 9980
                          Gotta give you the idle mix screw tips. Those are weak and suck.
                          • mikubuilder
                            • Jul 2011
                            • 548
                            • Westland, Mich.
                            yeah, that little tit will prevent you from swapping bowls into earlier carbs, plus brass tube doesn't line up right
                            Nick
                            1982 Virago 750 (it's alive!)
                              Most of the later carbs don't even use that rubber plug so that usually is not an Issue, only the first part of the '80 model year used that plug.
                              The brass tube IS the true issue.
