My front brake lever is harder to pull than any other bike I've had. When used alone it seems to stop as well as that single rotor can be expected to. With help I've switched to steel brake lines all around. That came with a master cylinder cleaning and fluid flush of course.
I'm still a bit worried about the lever pull. It doesn't move much. I don't have much adjustment left on the plunger screw - it is mostly backed out. The lever moves little now and even less if I run the screw down.
1) Should the front brake really haul my XJ to a quick stop by itself?
2) Should I be concerned about the short hard pull?
3) If so, what should I do about it?
Thanks experts!!!
Thanks experts!!!
Yes, it will stop the bike, but not nearly as well if all brakes are used. Yamaha put put dual discs on for a reason.
