Re: Grabrail
+ More Options
Posts
  • wildbill
    • Feb 2003
    • 346
    • western NC
    Re: Grabrail
    Folks a little later I will be searching for a grabrail or two for my bike,a 78E standard.What you use to put the bike up on its centerstand.Have space for one on each side.Runs from top of shock to a tab below the frame.Does anybody have any spares or willing to part with one or two? Thank you PS am using a 2 ton floor jack to get the bike on the centerstand.The stand is about froze up any suggestions on freeing this up.Have tried lubing doesn`t seem to help.
    Bill Harvell
  • nashville_bill
    • 605
    • Nashville, TN
    Take it off the bike, look for wear, clean it, and then lube it.
    Bill Murrin
    Nashville, TN
    1981 XS1100SH "Kick in the Ass"
    1981 XS650SH "Numb in the Ass"
    2005 DL1000 V-Strom "WOW"
    2005 FJR1300 Newest ride
    1993 ST1100 "For Sale $2,700" (Sold)
    2005 Ninja 250 For Sale $2,000 1100 miles
    • wildbill
      • Feb 2003
      • 346
      • western NC
      Thanks,the only problem is I don`t know if the PO ever did.It is funny something so simple can be such a BIG pain.Any tips or ideas?I tried to take it off before,no luck but I did invent some new words to call it. Will need to cure this sooner or later,better sooner.Thanks
      Bill Harvell
      • Ken Talbot
        • 4251
        • Revelstoke, BC
        With the bike leaning on the sidestand, you'll need to get underneath with a decent pair of long-handled pliers to remove the centrestand spring. Then it should be a fairly simple matter to remove the nuts from the two pivot bolts, tap the bolts out, and watch it fall to the floor.
        Ken Talbot
        • wildbill
          • Feb 2003
          • 346
          • western NC
          I rolled the bike out in some bright sunlight so I could see what I`am doing.Worked the centerstand up and down and gave it a good spraying of PB Blaster and while I was into it gave the sidestand a good spraying to.For now both work smoothly.Still to cold here to try to do to much on the bike outside.Will keep a eye on it. Thanks
          Bill Harvell
