Folks a little later I will be searching for a grabrail or two for my bike,a 78E standard.What you use to put the bike up on its centerstand.Have space for one on each side.Runs from top of shock to a tab below the frame.Does anybody have any spares or willing to part with one or two? Thank you PS am using a 2 ton floor jack to get the bike on the centerstand.The stand is about froze up any suggestions on freeing this up.Have tried lubing doesn`t seem to help.
Re: Grabrail
Take it off the bike, look for wear, clean it, and then lube it.Bill Murrin
Nashville, TN
2005 DL1000 V-Strom "WOW"
2005 FJR1300 Newest ride
2005 Ninja 250 For Sale $2,000 1100 miles -
Originally posted by nashville_bill
Take it off the bike, look for wear, clean it, and then lube it.Will need to cure this sooner or later,better sooner.Thanks
Bill HarvellComment
With the bike leaning on the sidestand, you'll need to get underneath with a decent pair of long-handled pliers to remove the centrestand spring. Then it should be a fairly simple matter to remove the nuts from the two pivot bolts, tap the bolts out, and watch it fall to the floor.Ken TalbotComment
Originally posted by Ken Talbot
With the bike leaning on the sidestand, you'll need to get underneath with a decent pair of long-handled pliers to remove the centrestand spring. Then it should be a fairly simple matter to remove the nuts from the two pivot bolts, tap the bolts out, and watch it fall to the floor.Bill HarvellComment
