Help Diagnosing Engine Noise
  • Swattastic
    • Jul 2011
    • 5
    • Front Royal, Va.
    I went to a ride the other day on my 79SF and halfway thought the ride, I started to hear a clicking sound from cylinder 1. I now have smoke coming from cylinder 1 and a small oil drip out of the headers and the cylinder meet.
    79 SF
  • jwhughes3
    • 2798
    • Home of the Alamo
    Your #1 header pipe - is it original? The original double-walled pipes can break a weld and rattle inside - might be the "clicking".
    I would pull exhaust and check for looseness - clean out exhaust outlets looking for oil - new gaskets and re-install.
    You might also check valve clearances - they might be off and could contribute to extra valve train noise - though close tolerances usually mean a quiet valve train versus noisy.
    John
    '81 XS1100H - "Enterprise"
    • Yard Dogg
      • Mar 2010
      • 884
      • Tri-Cities, Wa
      Check compression, you may have a blown head gasket. You might also pull your valve cover and make sure a valve seal didn't work itself loose. If it did, it might be banging around inside the valve spring.
      • mack
        • 2411
        • Ontario, Canada
        Sounds
        Like a valve guide seal on your #1 exhaust valve.
        mack
        79 XS 1100 SF Special
        HERMES
        original owner
        81 XS 1100 LH MNS
        SPICA
        78 XS 11E
        IOTA
        https://youtu.be/wB5Jfbp6SUc
        https://youtu.be/RaI3WYHSuWA
        Frankford, Ont, Canada
        613-398-6186
        • Swattastic
          • Jul 2011
          • 5
          • Front Royal, Va.
          Anyone live in Northern Virginia or around Front Royal Va, that might be willing to help me repair the my bike. I will Bring the beer and my bike to you.
          79 SF
