Headlight kill switch
  • Clyde K.
    • Sep 2010
    • 83
    • Grand Junction, CO
    I rewired my 78 so that the LED driving lights and tail lights come on when I start the bike and the ON/OFF switch controls the head light. I don't recall exactly what I did (hell, if it weren't for flashbacks I wouldn't have a memory at all) but with a wiring diagram it wasn't that complex. I bought a light bar for my bike and changed the incandescent bulbs out for LEDs. It works for me.
    Gunnery Sergeant, USMC (Retired), (A gung ho, lifer, Devil Dog) Semper Fidelis
    XS1100E, 11.5" XV1100 shocks, "no name" 4 into 2 headers and turn out mufflers, stock air box, 140 mains, spade type fuse block, volt meter, LED conversion on running/turn/brake/tail lights, aux front driving and running light bar, 850 FD swap, Chrysler electronic VR. Ugly as a monkey's butt - runs like a scalded ape (WHEN IT RUNS)
    • Yard Dogg
      • Mar 2010
      • 884
      • Tri-Cities, Wa
      Dude was right. You can run a toggle switch directly off of your fuse panel and mount them underneath somewhere. You will need one for the circuit that feeds all the dash lights and headlight, then one for the tail light. If you are planning illegal activity I recommend spring loaded license plates that flip over at the touch of a lever.
      I removed the reserve lighting unit from my XJ and will add a bar mount toggle switch so I can turn it off when I'm tinkering on stuff to avoid running down the battery. It's more reliable that way. I hate un-needed gizmos that can leave you limping home or stranded.
      • ManagerMike
        • Mar 2010
        • 445
        • S.E. Michigan
        I think only the 78 had them since US DOT says after 78 the headlight had to be on when running so it was eliminated.
        John
        Actually, the DOT headlamp law was effective for the 1976 model year for all bikes sold in the U.S.. From what I've read, the 78 still had the light switch in the right handle assembly simply because Yamaha still had a bunch of handle assemblies with the switch in stock, and didn't want to throw them away just because of some pesky law in America. They made the bike compliant with the headlamp relay.
        I re-purposed mine as an override for the headlamp modulator I installed at the output of the relay, with the switch in the off position the headlamp flashes, in the on position, the headlamp is on steady.
        So, to get back on topic, a swap of the rh control with one from a 78, and a disconnect of the headlamp relay would get the results you want without a bunch of electrical jiggery-pokery.
        '78 E "Stormbringer"
