need new cct QUICK..raptor 700
  • silver_ride
    • Aug 2011
    • 41
    • Minneapolis, MN
    Today i found out my oem CCT is fubar, and I've got a big road trip this coming sunday thru wednesday! So I found this raptor 700 acct on ebay and I'm hoping I can get it shipped fast...
    just wondering what you guys have to say before I order it. From what I've found on here so far, it should fit fine, bolts might be a little tight.. anything else? Thanks in advance
    80 XS1100G
    They are 'bottom' holes, so your original allen bolts WILL have to be shortened bout a quarter inch.
      Make sure you follow the procedure in the manual for cam chain adjustment when you change it and have your bike on the center stand. You don't want to throw the cam timing off.
      • silver_ride
        • Aug 2011
        • 41
        • Minneapolis, MN
        So you're saying go buy shorter bolts, or actually physically cut them? Can/should I shim them out w some washers as a last resort? You are dealing with a mechanically handicapped person with very little experience here..
        80 XS1100G
          Can do that, or better yet run down to your local Ace or Tru-Valu in their specialty trays when U get the other tensioner and get a couple metric allen bolts shorter for less than a buck. For reference, just put one of the original bolts thru the stock tensioner and use replacements that protrude the same distance on the replacement tensioner.
          • Poprock
            • Apr 2005
            • 594
            • Oregon Coast
            I'm running a Raptor CCT. I ground the ends off my bolts. Also made a gasket out of some fabric reinforced rubber material. That and some RTV and it's tight as a drum.
              Be very careful about cutting or grinding the old bolts. As you say you are mechanically handicapped, if you don't have the first couple threads on the cut bolt right when you go to thread them in the hole you are just going to F' up the threads in the hole.
              Just go by new bolts. You could bet 2 shiny new stainless bolts for under $1.
                +1 what Natemoen stated! A gasket is NOT necessary as they are both machined surfaces. A thin film of high-temp grey silicone will seal from any seep or leak....cleaning preperation is key always. This also goes for valve cover, shifter cover, oil pan and clutch cover.(still have new OEM gaskets in packages on shelf for these).
                • silver_ride
                  • Aug 2011
                  • 41
                  • Minneapolis, MN
                  Just to follow up, if anyone's curious... Got the CCT yesterday and installed it, and ive never experienced the bike running this well and idling this smooth in the year ive owned it, quite an improvement. But im not sure why i had to go buy shorter bolts? the flanges (or whatever its called) seem to be the same size/length on the stock CCT
                  80 XS1100G
                  • GLoweVA
                    • Jun 2011
                    • 1957
                    • Virginia Beach, VA.
                    I also put 2 raptor ACCTs in my G and SG and I didn't have to shorten my bolts either.
                    Maybe the shorter bolt issue is on the Vision/V-Max ACCTs?
                    80G (Green paint(PO idea))
                    The Green Monster
                    Got him in '04.
                    bald tire & borrowing parts
                    Scarlet
                    Got her in '11
                    Ready for the twisties!
                    81H (previously CPMaynard's)
                    Hugo
                    Cold weather ride
                      Nope, not an issue with the vision one either.
                        Interesting, casting must just be a tad shorter on the Venture/VMax tensioner housing. Being 'bottom' holes, just didn't wanna see anyone fracturing the head casting.
