Ben go to a paint dealer (Sickens or P&G) and ask them, they will tell you to use hardener with your clear coat and paint as well, they will also advise mix ratios and pressure for your paint gun. Dont know if you used a spray can or not but spray can paint is suceptible to gas disolve......
Bruce
[QUOTE]Originally posted by ae7f
[B]My shiny new black, clear-coated gas tank looked good until fuel vapors killed the paint job.
What paint should I have used?
I''ve got to agree with Danny on this one. The first bike I painted I used rattle can's and followed with a polyeurothane coating. The plastic coating is very resistant to gas.
Brian
remembering the same thing!
It seems that the urethane paints are indeed the types to use on motorcycle gas tanks.
There are lots of places to order paint online. It seems to me that doing the job myself is not going to save me very much money when considering the cost of shipping the paint to me and my inexperience with the paint gun.
Perhaps my best bet at this point is to let a shop give me an estimate for the tank and side panels for the following type of job:
*tank and side panels are pre-prepped, primered, sanded, ect.
*gas-resistant gloss black urethane base color coat
*gas-resistant urethane clear coat
I think if I could get it done for $100 I'd be getting a steal, though $150 would probably be more realistic.
I could do the other simple paint jobs - frame, components, etc. - with lesser quality paint and with my painting experience.
What do you guys think?
I guess if anyone knows of another way I can get the paint reducer, hardener, and black paint for a smoking deal, I might consider otherwise. From my figures, 1 quart of paint should do around 112 square feet, which should be enough for a couple of coats on the tank and side panels.... ??
Will "rattle can" Krylon primer work underneath a urethane color coat?
