slipping out of first
  • Nightengale
    • Jun 2011
    • 521
    • Hampton, VA.
    i have had my bike slip out of first then back into gear when i let off the throttle. this has only happened a few times and only when i really take off quick. when i ride normal there is no problem what so ever, it shifts through all gears just fine. is this the clutch or do i need to do the dremel gear fix. also i just adjusted my clutch, before this strarted to happen.
    xs1100 hartail bobber
    http://i1169.photobucket.com/albums/...-38-36_563.jpg
    • 9981
    Unfortunately the gear dogs are worn and need repair. I went through the same thing when I recently repaired a second gear problem.
    I repaired the second gear on a secondary shaft from another engine and didn't look close enough at the first gear dogs.
    Got practice 2 weekends in a row pulling the tranny apart. Fix 2nd gear too while you rin there and check the others thoroughly.
      Yep, the symptoms sound just liek the ole' gear slipping problem. Dremel is your friend...Really!
      Definitely dremel 2nd and 5th while your in there. It is very uncommon for the rest of the gears to be effected, but look any way, You would hate to find out you missed one after you get it all put together!
        • 9981
        Yes, I did..
        • CatatonicBug
          • 6117
          • Clinton, UT
          Originally posted by BA80
          Yes, I did..
          I did too... TWICE! Started out with 3rd gear, so I fixed that. Then it started in 2nd, so I fixed that. Then 5th gear went. So I did ALL of them. No problems since then.
          • haywardguy929
            • Jul 2012
            • 345
            • Hayward, Wisconsin
            I've seen the fix thread and got a feeling ones in my future and not looking forward to it. Time wise if you stayed on it how much time is involved for a novice?
            81 H
            • CatatonicBug
              • 6117
              • Clinton, UT
              Depends on how determined you are. I can do it, start to finish, in 4 hours. Took me 6 hours the first time. Allow a full Saturday afternoon at least.
              • Aches n Pains
                • 349
                • Reston, Va.
                Interesting transmission explanation
                I found this helpful in understanding what's happening in the transmission.
                http://www.gadgetjq.com/transmission.htm
                1995 KZ100P
                Pods, jets, pipes, cam adjuster, oil cooler
                1977 Ironhead - custom build
                Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                  Personally, I am abit OCD about doing such projects, known to skip meals and sleep maybe 5-6 hours till they get done. My first one took a while, and I needed some breaks, to go to work and let it sit till I calmed down. IT is not an easy task to get it reassembled. Not really tricky or requiring special knowledge or tools, it just requires you hold your mouth and tongue just right for that countershaft to slide into place. I had it apart in about 4-5 hours. I spent easily two hours dremmeling the gears. Then hours and hours over a three day period till I coaxed that countershaft back in.
                  If all the stars align and the shaft goes back in, for a first timer doing it, I would allow all of a Satruday and half a Sunday to button up all the case covers and such. Heck, I spent 3-4 hours just scraping the bloody gasket material off the shift side cover, it is a PITA to get to tucked in behind the timing cover and the middle drive and frame and such.
                  • Nightengale
                    • Jun 2011
                    • 521
                    • Hampton, VA.
                    gears
                    Found a set of gears on eBay for under 100 bucks, I'm thinking about getting them, and making sure there right, so that I can take out the old gears and put these in place, and keep the olld set as a spare. I figured this might save me some time
                      • 9981
                      Don't just slip them in there, go ahead and rework the dogs and slots. Also, do the washer swap on 2nd gear.
                      You really don't want to do it twice.
                      • WMarshy
                        • Apr 2009
                        • 2402
                        • Mexico NY
                        You might want to shoot a message to out local parts guy Andreashweiss to see what he can do on price of a transmission...
                        '79 XS11 F
                        Stock except K&N
                        '79 XS11 SF
                        Stock, no title.
                        '84 Chevy K-10 "Big Blue"
