Busy winter
  • McShafty
    • Jul 2012
    • 31
    • Melfort, Saskatchewan, Canada
    Busy winter
    looks like im parking my mns early. chcked the oil the other day and it reeked of gas. checking things over and also found plug 1 has become really fouled with oil. plugs were replaced 600km ago. time to fix this and do all those little things i have planned for the old girl. time for a winter overhaul
    81 MNS
  • jjz28
    • Apr 2012
    • 1023
    • Beckley, W. Va.
    I have done the gas oil thing twice this year. I need to fix my floats valve seals, which will be done this winter. But, if you change your oil and filter, you should be good to go. Put in a new plug and ride, check it when the riding season is over. At least, that is what i would do. Good luck.
    77 XS750 2D completely stock
    • WMarshy
      • Apr 2009
      • 2402
      • Mexico NY
      If your oil has gas in it dont forget to change it! An oil filter alone is not enough if the viscosity of your oil has changed...
      '79 XS11 F
      Stock except K&N
      '79 XS11 SF
      Stock, no title.
      '84 Chevy K-10 "Big Blue"
        I would have to agree, change the oil and filter, clean the plug and ride. Make sure you didn't damage anything from the gas in the oil. No sense fixing something if it isn't.damaged.
        • Yard Dogg
          • Mar 2010
          • 884
          • Tri-Cities, Wa
          I think you should fix the carbs. One afternoon of work Vs washing out your bearings. Sorry guys, I had to disagree with you.
          • McShafty
            • Jul 2012
            • 31
            over the nex bit im going to pull the carbs and service them. pull the head and see why ive got oil in #1, i wanted to take the engine to get recoated so might as well get that done at the same time. i also plan on redoing the whole iringing harness the wiring has become brittle. im tired of roadside electrical fixes lol
            81 MNS
            • Yard Dogg
              • Mar 2010
              • 884
              • Tri-Cities, Wa
              Well I didn't know you had all that to do too. Drive it til it drops if you know it's coming.
              • WMarshy
                • Apr 2009
                • 2402
                • Mexico NY
                You dont understand its not an option, change your oil or suffer a wiped bearing. Fixing the carbs is more of an option because if you wanted to you could just add an on/off fuel T and forget about the leaky valve seats (and leaky petcocks as well, the problem is never just one or the other its both are not working properly)... Now if you dont suspect any gas in your oil then its your call to change it but if you notice the level has increased any then be forewarned.
                '79 XS11 F
                Stock except K&N
                '79 XS11 SF
                Stock, no title.
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  That's what I meant marshy, fix the carbs or suffer bearing loss. 1 afternoon of work or a lot of money and maybe worse damage later.
                    I guess I left out the part about having to fix the cabs as well. Yes, it is a mandatory thing.
                    No sense adding in more parts and joints to fail.
                    • McShafty
                      • Jul 2012
                      • 31
                      pulled the carbs off tonight. im gunna pull em apart on the weekend. not one of my favorite jobs... all part of the fun of owning a classic
                      81 MNS
                      • jjz28
                        • Apr 2012
                        • 1023
                        • Beckley, W. Va.
                        I did mine in a couple of hours, BUT, I have done them 3 times. Do EVERYTHING right the first time, take out the emulsion tubes the first time and clean the little hole in the bowl for the enricher/choke and buy some new float valve seals. Also check your petcocks and fix if needed. You must have a lot of oil on that plug, i thought it was just a little or fouled. Good luck.
                        • McShafty
                          • Jul 2012
                          • 31
                          as i go im taking pictures. ill get them up on here soon. so you can see what i mean by oil in #1
                          81 MNS
                          • McShafty
                            • Jul 2012
                            • 31
                            cyl #3 and #4
                            cyl #1 #2
                            plug from #1
                            81 MNS
                            • Yard Dogg
                              • Mar 2010
                              • 884
                              • Tri-Cities, Wa
                              Yes sir, they need a little. It'll survive.
