XJ throttle cable...
  • gringojason
    • Mar 2010
    • 60
    • Newport Beach, CA
    Hey everyone...
    A couple of weeks ago, I posted about my throttle cable snapping and having to tow my XJ home the day before I left for vacation. Well, I am back from vacation and now I need to replace the throttle cable.
    Where's the best place to get a new throttle cable? Thanks...
    '82 XJ1100
    Jason
    They are all over the place. I get mine from the cheapest seller on ebay at the time.
      XS cable doesn't fit the XJ, Bug.
      I see that Boats.net says they have them. The part number is 10M-26311-00-00
      http://www.boats.net/parts/detail/ya...311-00-00.html
      Not cheap though, but that's about the going price for them. I don't know if there's an aftermarket cable or not. I found an old Yammy store that had a couple left in stock a while back and grabbed them. I always carry one and a clutch cable with me on trips.
      • gringojason
        • Mar 2010
        • 60
        • Newport Beach, CA
        Thanks for the link. I found a couple cheaper on ebay for the XJ650...
        http://goo.gl/QdyPG
        Do you know if that cable will work?
        '82 XJ1100
        Jason
          Oh yeah... And the Boats.net link says the part is obsolete and unavailable. I'll refer you to this post though. Looks like you can get them for $26 from Chacal on xjbikes.com.
          http://goo.gl/QdyPG
          It's a different part number, so I doubt it.
          • gringojason
            • Mar 2010
            • 60
            • Newport Beach, CA
            Thank you. I found the part listed and just emailed Chacal to order it. Much appreciated.
            It looks pretty straightforward to install. Any tips or suggestions? Thanks...
            '82 XJ1100
            Jason
            • gringojason
              • Mar 2010
              • 60
              • Newport Beach, CA
              Since nothing in life is easy, I got a reply back from Chacal saying that the throttle cable is no longer available and they are trying to get a reproduction, but it will be 2 or 3 months.
              I couldn't find any used on ebay and the best thing my Google search came up with was this...
              http://www.jpcycles.com/1982-yamaha-...bles/exact-fit
              It shows it as 32" with a 6" extended length, for a total of 38". Is that long enough? Will that work for my 82 XJ1100? If not…any other suggestions on finding a cable that will work? Thanks for your help…
              '82 XJ1100
              Jason
              • lee_dutcher
                • Apr 2009
                • 822
                • mason city iowa
                post up a picure of what it looks like and ill send u one for free just pay shipping.... have 10 throttle cables and have no idea which one goes where...
                1980 gs1000g "stock"
                • gringojason
                  • Mar 2010
                  • 60
                  • Newport Beach, CA
                  Lee...wow. Thank you so much. I just took the old one off and here are pictures...
                  Also, Len from XJ4ever gave me the specs of the cable...
                  HCP2700
                  OEM throttle CABLE
                  wire overall length: 47-3/8"
                  sheath overall length: 43"
                  uses a 5.90mm OD x 6.10mm wide barrel at one end
                  uses a 5.85mm OD x 4.05mm long flat disc at other end
                  8.00mm past stop flange with rubber cover
                  60-degree plastic tube at throttle end
                  07-HK-01-3-J
                  Do you have one that fits those specs? If so...I would be eternally grateful. Just let me know how much to send you. The zip code I need it shipped to is 92704, in CA. Thanks again...
                  '82 XJ1100
                  Jason
                  • lee_dutcher
                    • Apr 2009
                    • 822
                    • mason city iowa
                    ill get back to you later tonight... let me measure and compare..
                    • gringojason
                      • Mar 2010
                      • 60
                      • Newport Beach, CA
                      Lee...did you get a chance to measure the cables you have? If you don't have one, I need to figure something else out. Thanks...
                      '82 XJ1100
                      Jason
                        There's always used... Might try something like this and lube it up good when you get it?
                        http://www.ebay.com/itm/THROTTLE-Cab...dbf9d8&vxp=mtr
                          I emailed Motion Pro, who makes aftermarket cables for motorcycles. I've used their clutch and speedo cables. Here's the email..
                          Hello.
                          I own several 1982 Yamaha XJ1100J motorcycles. I'm a member of a website of these old Yamahas and lots of people are running into the same problem. Some parts are becomming "Unobtainium" or discontinued. The throttle cable is one of them. It's the only bike these cables were put on. I have no idea of the re-tool process or how many you would have to sell to make it worth your while, but would you ever consider making a limited run of these cables? There's still hundreds and hundreds of these bikes on the road and I don't know who else to contact about it. You make the clutch and speedo cables for it still, but the throttle cable is getting to be impossible to find. Thank you for your time, and if there's any way I could help in this process, don't hesitate to write. Thank you very much for your time.
                          And their reply:
                          Hello Tod,
                          We have never produced a line of replacement throttle cables for this application so generally we have no information documented.
                          I don’t see anything in the works to start carrying these as an off the shelf option, but I’d be happy to pass on your request to do so.
                          In most cases like this it’s best to send the cable in for duplication. While we can’t be 100% sure of what we can do in till we receive the cable for review, we can usually duplicate most throttle cables.
                          Just to supply all the info I can, the cost to custom make a black vinyl throttle cable I would estimate to be $35.00 to 50.00 per cable excluding any shipping cost.
                          The current turnaround time to complete a custom cable order is 6-7 working days excluding shipping time.
                          All custom cable orders are prepaid on a credit card with a no return policy unless for warranty consideration. We do require the billing address on the card is the same as the ship to on the order and the card holder is the one placing the order.
                          Send sample cables to:
                          Motion Pro
                          Attn: Custom Cables
                          867 American St
                          San Carlos CA 94070
                          Please include a brief note stating what you need done and a means to contact you during the day.
                          Once we receive your sample, we’ll review your request and contact you to confirm the details of your order and get your credit card number at that time.
                          I hope you find this information to be of assistance, please feel free to contact us with any questions you may have.
                          Thanks,
                          Matt Groshong
                          Motion Pro Inc.
                          Custom Cable Sales
                          P(650) 594-9600 Ext.119
                          F(650) 594-9610
                          Matt@motionpro.com
                          www.motionpro.com
                          So.. if you sent him your old cable along with the specs that that Len guy sent, it sounds like they might be able to make a new one? I would suggest to them, though, that the plastic end up at the throttle handle be replaced with metal like the XS cable is. If I didn't have a couple extras already, I'd probably try this out. If someone lived anywhere near this plant, it might be a big benefit to others if they could take an old cable by and see if they can even reprodoce it, and how much they think it would be, along with any discounts for multiple orders if we got a group buy from people here.
                          Just a thought.
                          • lee_dutcher
                            • Apr 2009
                            • 822
                            • mason city iowa
                            does the xj have 2 cables coming from the throttle tube..like a push pull type? or is a magna?
                              Just a single cable.
