Brake/Oil Light
  • conquest87tsi
    • Jun 2012
    • 190
    • Jackson, Minn.
    Brake/Oil Light
    So a few months ago i replaced all my lights with LEDs. Not surprisingly my brake/oil light has been on ever since. I'm sure because the brake light doesn't pull enough amps. Does anyone know how to bypass the checker unit for the brake circuit?
    I remember seeing something about jumping the blue and blue/yellow wires at the unit. If this bypasses the brake checker I would just remove those pins. Want that oil light off, but then again maybe I'll miss it when it's gone.
    This is a different question, but does anyone know a good location to mount an oil temp sensor?
    1979 XS1100 SF
    1979 XS750 SF
    Previous Rides:
    1981 KZ650CSR
    2006 VTX 1300C
    1986 Radian 600
  • Eveready1100
    • 539
    • Childers, Queensland,Australia
    Have a read, mate. - CLICK
    Should help you out.
    • Gallaecus
      • May 2011
      • 254
      • East Haven Connecticut
      try wiggling the LCU or un-hook it ....twist it around...and hook it back on...JAT
      Steven
      1981 XS 1100 LH
      1979 XS 1100 SF
        • 8894
        Wiring Bypass:
        Light Checker Unit : Unplug unit and connect blu and blu/yel together at the harness plug.
        • je2wheeler
          • Feb 2010
          • 180
          • Moved to NC to help my Dad
          Wiring Bypass:
          Works like a champ. I wired in one of those BACK-OFF Safety Modules that flash the brake light fast five times to steady on, or it can be wired to flash fast three times to steady on for five seconds and keep repeating. I wired in a double throw switch so I can select one of the two. It did cause the oil/tail/brake light to blink randomly. Now I don't have the oil/tail/brake sending me Morse code.
          1979 XS 1100 Special - Nicknamed "MONSTER"
          ATC fuse box
          Braded stainless brake lines
          4/2 aftermarket exhaust(temp until stock is re-chromed )
          V-Max auto cam chain adjuster
          Brake light modulator with reserve brake light bypass
          Vetter Windjammer III faring
          Tkat Fork Brace
          "Americans have the right and advantage of being armed; unlike the citizens of the countries whose governments are afraid to trust the people with arms”
          James Madison, The Federalists Papers
