Rear shocks
  • ViperRon
    • Feb 2011
    • 1062
    • Woodstock, VA
    Rear shocks
    The information I am looking for was on the Yamaha site till last year on the parts fiche for the 1980 G model. At one time I had captured them but no longer have the CD I saved them on. There was a technical reference sheet about the upgrade of the shock springs when installing saddle bags and fairing. There were actually about 8 sheets dealling with shocks emmisions carbs electronics etc. These sheets actually showed the procedure for dissasembly of the rear shocks and repacment of a heavier spring. It also showed the picture of the tool used to compress the spring.
    If anyone knows where I can reference this info about the shocks or has it in electronic picture form I would appreciate it.
    Rodan
    1980 G Silverbird
    1198 Overbore kit
    Grizzly 660 ACCT
    Barnett Clutch Springs
    R1 Clutch Fiber Plates
    122.5 Main Jets
    ACCT Mod
    Mac 4-2 Flare Tips
    Antivibe Bar ends
    Rear trunk add-on
  • gryphon51
    • Aug 2012
    • 45
    • Abbotsford, B.C., Canada
    I have used a winch strap to compress the shock spring on the monoshock for my dualsport bike, and it would be about 4 times the strength of the ones on these bikes
    1979 XS1100
    Was going to be a ratbike, instead it is
    Turning into a "Labour of Love" Restoration...
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      Compression is not the goal taking it appart is but I do thank you for the response Gryphon51.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
        If you compress the spring and take the keeper out of the top of the spring cap, the whole shebang comes apart....
          You need something like the yellow one of these....
          ... This compresses the spring away from the top eye, then you can remove the slotted washer that holds the shock together. The hydraulic parts doesn't come apart.
          • ViperRon
            • Feb 2011
            • 1062
            • Woodstock, VA
            Thanks Steve that will work but I think I'll make it i was going to use a different design but needed to see how far to compress with this I can go slow.
            Rodan
            1980 G Silverbird
            1198 Overbore kit
            Grizzly 660 ACCT
            122.5 Main Jets
            ACCT Mod
            Mac 4-2 Flare Tips
            Antivibe Bar ends
            Rear trunk add-on
              I have the tool Crazy Steve pointed out. It works just fine on the stock shocks. It works even better on Progressive shocks. I found the tool for cheap on Amazon.
              • gryphon51
                • Aug 2012
                • 45
                need to compress it to take it apart, as mentioned. and my pleasure.
                1979 XS1100
