I disagree Don. When the 2nd gear dogs are disengaged that 5th gear wheel (on the shaft you are speaking of) and the 5th gear pinion (on the inermediate shaft) are freewheeling until the 2nd gear pinion engages to the 5th gear pinion (moved over by the MIDDLE fork). It doesn't actually have any dogs, the 5th gear wheel is splined inside to accept the teeth of the second gear pinion (again on the intermediate shaft) and that is what actually engages 5th gear.
http://www.powersportsplus.com/parts...ION/parts.html
Did you not just repair the gears on one of these bikes? You need to quit smoking your home grown cigarettes and then posting.
