I only found one other post about this issue, so I'm looking for more info.
5th gear sometimes make a grinding noise. It its very light, not the grind of gears that aren't meshing. Works perfectly, just sometimes makes a light grinding noise. When it happens, I can feel the vibrations in the shifter.
Is it possible that the 5th gear has slid along the shaft far enough that it sometimes contacts the case? The grind definitely sounds like this is what causes it.
Is there a circlip for 5th, and can it be accessed somewhat easily since it is on the end of the shaft?
Did you not just repair the gears on one of these bikes? You need to quit smoking your home grown cigarettes and then posting.
