any clutch options for a hard rider?
  • adam79
    • 184
    • Tacoma, WA
    Just picked up my new xs, and it may need a clutch soon. I ride it pretty hard, is there any other options for a clutch besides the stock replacement I can get at the yamaha dealership?
  • James England
    • 3039
    • North of England
    They're still making them new??!
      • 9980
      You don't need a new clutch for your "NEW" XS. THIS should take car of any slippage you have. And, running the correct oil in the engine.
        New clutch disc should'nt be needed. First, loosen cable adjustment and remove the two screw cover on the clutch side and adjust clutch at the throw-out bearing first by loosening the lock nut and turning screw in till contact is felt. Back out a quarter turn, holding in place, tighten lock-nut. Then re-adjust cable free-play. If that doesn't help, tipping bike on left side and removing clutch cover without draining oil can easily be done. Replace the clutch springs using Barnett springs ONLY as the replacement. Re-adjust and ride some then re-check both adjustments. Synthetic/semi-synthetic oils don't play well with these clutch disc.
        • adam79
          • 184
          • Tacoma, WA
          good. I forgot that those springs went soft, I replaced them on my 1st xs
          • adam79
            • 184
            • Tacoma, WA
            I cant find xs1100 on that website, so I want to double check the part number with you guys for the right barnett spring set. 501-58-06045 ??
              • 9980
              • CaptonZap
                • Jun 2010
                • 1748
                • Denver
                According to their chart, that fits all the XS11's. CZ
                • Yard Dogg
                  • Mar 2010
                  • 884
                  • Tri-Cities, Wa
                  I bought these for my last bike and it fixed the slippage. Can't beat the price either.
                    • 9980
                    http://www.bikebandit.com/ebc-csk-cl...g-kit?m=147104
                    The EBC springs don't last, the Barnetts do.
                    • Yard Dogg
                      • Mar 2010
                      • 884
                      • Tri-Cities, Wa
                      If you've had both and you swear by this I will buy the Barnetts. I'll probably need to, my bikes been sitting for a decade.
                        I am going to need to change my clutch springs again soon after only about 4000 miles on the ebc springs. Going with the Barnett this time, EBC springs don't last.
                        Barnett also makes the friction discs for our clutch as well.
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          I have read mixed reviews about the barnett steel/friction plate kit and would avoid replacing them if within spec. Usually just a light hand sanding with some 220 grit to knock the junk off the steels are all they need. Replacing the frictions arnt a bad idea but usually the springs solve the slipping...
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                          '84 Chevy K-10 "Big Blue"
                            +1. EBC springs don't last, and Barnett's will fix you up. I used to ride pretty hard, but got tired of tearing things up that nobody had heard of getting torn up before. Especially me.
                            • Yard Dogg
                              • Mar 2010
                              • 884
                              • Tri-Cities, Wa
                              Barnetts sound good to me.
