I'm looking for a way to repair a broken float post. The top part of the float pin hole is broken. The bottom half of the hole is still intact. I found a thread on here before where someone drilled a tiny whole in the post and threaded a piece of wire through it and twisted it around the pin. Now I can't find that thread. I was wondering if anyone knows if it's still on here or have a better solution to my problem.
Looking for float post repair
About 12 years ago I was rebuilding a set of carbs for a friends KZ650 and when trying to to tap out a badly corroded float pin the top broke off. I repaired it using low temperature aluminum repair rod and a butane pencil torch.
You build up the post with rod then sand it back to shape and carefully re-drill the hole through it. He had the bike for 5 years with that fix before selling it and as far as I know it's still working.80 MNS; 80 F; 82 Maxim 650
It Is somewhere, but you know the idea already. Drill a hole and tie it down with some wire. That's really all there is to it.Nathan
I think this might be the one you're talking about - CLICK79 SF Special W/ Stock all original motor @ 384,000klms
Float post repair
I have done the fix you are talking about. The top of the post had broken off even with the middle of the hole. After a lot of discussion here, I used a Dremmel tool with a 1/16th inch drill bit to bore through the center of the post almost half way down the post. I used stainless steel wire to loop through the hole and over the pin. I twisted the wire to secure the pin firmly in place. Do not try to get this too tight, snug will do. When you cut off the excess wire, be sure to leave enough of the twist to hold, but short enough it will fold out of the way. Be sure it does not interfere with float movement. Worked for me.
Sorry, I had photos of the repair, but they are gone somewhere into the eithersphere.
It is really not too hard, just take your time placing the hole so the wire will be out of the way. Let us know how it goes.1978 XS1100E "Goliath"
Full Pacifico faring
Hard saddle bags
Hard trunk
Uni air filter
In the process of restoration
It is impossible to rightly govern a nation without God and the Bible. George Washington
Let us with caution indulge the supposition that morality can be maintained without religion. Reason and experience both forbid us to expect that national morality can prevail in exclusion of religious principle. George Washington
I used the wire method for a while, but it did not prove good enough for me. I ended up making a new post out of aluminum and then machining the broken post flat, drilled a hole in it to accept the mounting stud of the new post and then press fit them together. I then drilled and tapped the assembly so I could use a small screw through them both to ensure they stayed together.
If you go this route (which does provide a very nice repair), be sure you only have a very light press fit or you will break the casting. Pretty cheap, weak aluminum in the carb bodies.-- Clint
