Complete rebuild
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Complete rebuild
    As soon as the roads start to ice up I am going to be doing a complete tear down of my XS. Every nut and bolt. I'm going to replace all seals, gaskets, and all hardware will be changed to stainless. All parts will be blasted and powder coated/painted.
    What should I be looking to upgrade/modify/replace while its all torn apart? I'm already planning on a new can chain and doing the 2nd gear mood while i'm in there. Also stainless brake lines, Tkat brace, screw on oil filter mod
    Anything else you can think of? I don't want to be tearing it apart again in a couple years for a worn out part.
    Thanks
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    New clutch springs, maybe the return spring for the shifter.
    Steering stem bearings on the triple trees, wheel bearings all around, fork seals. Depending how far you want to go, rebuild kits for brake system along with new pads.
    Also, not necessarily parts, but definitely lap the valves, oh..and new valve seals. ACCT if you do not already have one. and clean, clean, and clean ALL electrical connectors. Alot of folks have good things to say about De-oxit. Not tried it myself yet. But after you reconnect the connectors, coat the open backs with di-electric grease. Maybe change the pick up coil wires if they have not been done yet, chances are good they will need it before long anyway. Same for the fuse box.
    All I can think of right off. Hopefully the types of things you were looking for.
    • Tat2demon
      • Jun 2012
      • 718
      Exactly the kind of things I was looking for. I do have an acct and fuse box already. Forgot to post those.
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        • 7943
        Thanks
        Traxxion Dynamics or RaceTech suspension.
